98 RL 3.5 P1457 code
Old Apr 28, 2012 | 08:46 AM
wcltdnut's Avatar
4th Gear
List
Have the P1457 code, I have read about replacing the solenoid shut valve. where is this located ? and is the correct part number 17012-SV4-L31 ? Any help appreciated. I have a emissions test coming up.
thanks
dave
Old May 3, 2012 | 06:09 PM
pmendoza502's Avatar
try your gas cap first...
Old May 13, 2012 | 10:03 PM
MyNameIsEarl's Avatar
Hey,
I recently dealt with this problem and its a real pain in the butt. The P1457 code is referring to the EVAP system (the thing that takes gas fumes from your tank and puts in in the engine). Under your front-driver's side wheel well take out the cover, it helps to jack your car up and take the wheel off. Once the cover is off you will see a black boxy canister looking thing, that's the evap canister. What we did to make it work was on top there were some valves and we took them off and cleaned them up because they were sticking earlier. If that doesn't work either your gas cap is loose or you have a leak in one of the steel lines that runs under the car and those are practically impossible to replace.
Good luck!
Old May 13, 2012 | 10:04 PM
Oh, you also have to have a code resetter to make it go away.
mlody
Dec 4, 2019 02:11 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
Skirmich
Oct 1, 2015 12:59 PM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
