97 RL Will not shift back into reverse or park. HELP PLEASE
Old Jul 28, 2019 | 08:18 PM
Bighow104's Avatar
My car has been sitting in the driveway for a few months. I started it up and put it in reverse an backed down the driveway. I then put it in drive and pulled back up in the driveway, but the shifter would not go past the neutral position. I tried using the bypass slot to the right of the shifter but no dice. I had to disconnect the battery just to take the key out the ignition.
Old Jul 29, 2019 | 05:37 PM
OLD_HATCH's Avatar
There's a lockout switch on the shifter you could try looking at. Its a activated by the brake pedal switch. Dont know if it would work for you though
Old Nov 7, 2020 | 11:52 PM
I2canfix's Avatar
Try back light fuse under the hood! Brake lights would not work, If not check out the break switch sensor, your brake lights would be staying on!
Craig Vyvial
Nov 10, 2020 12:55 PM
cvzillest
Apr 15, 2015 12:12 AM
eckokid 00TL
Nov 6, 2011 08:28 PM
David Gurley
Dec 28, 2007 10:43 PM
Adam_Schwartz
1G TL Problems & Fixes
Jan 19, 2006 12:44 PM
