20 inch Rim OFFSET??
Originally Posted by Exantus78
what size offset will i need for the 2007 RL
RonJon Legends were designed with +45mm, and had to be reduced to +41mm because of the 4 piston front brake calipers. 18x8 and 19x8.
Some have used as low as +38mm. The trick is, as always, finding a high offset, now in a 5x120 bolt pattern, and lighter weight. The Acura A-Spec 18x8 s are still a whopping 28 lbs for 18's. I think RonJons are 28 lbs for the 19's.
If you pay for Enkei racing wheels for the RL, you can get them under 20Lbs a piece, but we are talking big $ also.
InFaMouSLink
Oct 30, 2015 09:43 AM
johnpancakes014
Sep 27, 2015 12:58 PM
