'02 RL differential fluid
Old Feb 26, 2012 | 12:06 AM
559RL's Avatar
9th Gear
Question '02 RL differential fluid
I decided to purchase the '02 RL and recently changed the differential with the valvoline 80w-90. Now I'm wondering if i should've used the fluid from the dealership instead. Also is there big difference between 80w-90 and 90. Any suggestions or advice?
Old Feb 26, 2012 | 01:08 AM
Team LR's Avatar
80-90 is wat we need to run, Oem fluid isn't ganna perform any better then the other brands. Change your fluid on a reg (15-20k)and you'll be fine n if you can check a couple times every few moths make sure you aren't losing any fluids you'll be even better
Old Feb 26, 2012 | 05:34 PM
Jimmay's Avatar
I run Valvoline Durablend in mine. Change it pretty much yearly. No problems what so ever.
SidhuSaaB
May 30, 2020 12:40 AM
LeVeL
Oct 18, 2015 04:19 PM
hpfiend
Sep 27, 2015 06:59 AM
Cexarin
Sep 23, 2015 07:43 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
