Pics of aftermarket wheels Thread
Mr Marco (09-28-2012)
#363
![](http://i174.photobucket.com/albums/w90/kenb350z/RDX/DSC_0322.jpg)
Looks good InfamousJamous. I'm going with my same setup I have now; however, matte gunmetal finish with 275/40r20 all around. Still going to sport that 20x10.5 in the rear, that just gives the RDX the balls that it needs.
#370
Thanks! Yea, I tested the limit's on how big and figured that 20x10 275 tire would be the max up front. I was running the 275 up front and 315 in the rear, now i'm running the same size wheels with 275 all around. I love the fact that I can fit a 10.5 in the back. ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
![](http://i174.photobucket.com/albums/w90/kenb350z/DSC_0669-1.jpg)
The following 2 users liked this post by KenB350z:
chrischabot81 (01-30-2013),
Mr Marco (07-04-2013)
user65 (02-01-2013)
user65 (01-30-2013)
#376
mstolars (08-16-2013)
#385
#386
Hi all - New owner of '11 Tech (get it delivered next week). Have spent hrs reading all the wheel/tire threads I can find, but still need advice on a few things.
Really appreciate comments/advice/thoughts/suggestions!
1) I really REALLY want Enkei RT6 in 18 x 8.5 but only offset avail is "0". [26.1 lbs vs. stock at 26-27 lbs so that's good]
![](http://www.enkei.com/images/truck_suv/enkei_rt6_chrome_large.png)
On another truck, had lots of inner wheel well cutting and some BFH work to make a +38 to a -2 work, so I don't mind doing some "rearranging", but with the brake/calipers or whatever is hanging out in the top of the front wheel well so close on the RDX, I can't figure out if this offset stands a chance of working or not when stock was +45?
2) First choice would be a little more "off-roady" look as I live in a very small rural area with lots of dirt roads. My fav tire of all time is Nitto Terra Grapplers. Smallest 18" they make is 255/60-18.
Diameter goes from 28.1" to 30" (6.7% taller)
Width goes from 9.3" to 10"
Weight: 36.5 lbs vs. stock 30 lbs. - 6.5lbs unsprung weight at each corner.
Think this wheel & tire combo stands a chance?
Next size is 20" x 9" (with +12 offset), but don't have correct bolt pattern of 5 x 114.3
- First priority is to get the rims to fit, so if the Nittos can't work, then I'd pick a different tire that'd work.
- Tread life isn't important, 20,000-30,000 miles would be fine.
- Other tires I'd consider:
1) Falken Ziex ZE329 in 235/55-18 - Me LIKEY this one ALOT!
2) Cooper Zeon XST-A in 255/55-18
3) Cooper Zeon RS3-S in 235/50-18 (like KenB350z has in 275/40-20)
4) Falken Ziex ZE512 in 235/55-18
5) Cooper Discoverer H/T Plus in 255/55-18
6) Nitto CrossTek CUV in 235/55-18 or 235/60-18 (1" taller- work??)
#388
Got the #2 from my short list above, the Cooper Zeon XST-a in 255/55-18 mounted up. A full 1" wider (9.3" vs 10.3" per Cooper's site) and .9" taller, and no rubbing. Nice meats! Has the widest sipes I've ever seen.
Pics to come soon.
Pics to come soon.
#389
^Waiting on your pics for sure...Had a set of Coopers a long, long, long time ago. Very soft tires.
#390
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
Sorry, too cold to wash the car to take pics....but soon. Love the tires, super sticky, and way cool looking.
Still want rims. Been looking at pics for hours.
Staying with 18", not lowering or lifting, don't want spacers.
After reading posts here, staying in the +20 or higher offset.
Unfortunately, think I still have to give up on the Enkei RT6 cuz they're 0 offset.....![Thumbs Down](https://acurazine.com/forums/images/smilies/thumbsdown.gif)
But, found another rim, 18" x 9" (5 x 114.3, +25 offset) I really like.
My new Cooper XST-a in 255/55 are approved up to 9" width.
http://www.ebay.com/itm/ALLSTAR-sp5ive-18X9-et-25-GRAPHITE-FULL-MACHINE-5X114-HELLAFLUSH-LOOK-/161041533339?pt=Motors_Car_Truck_Wheels&hash=item257ed2c99b&vxp=mtr
*** What will I be facing trying to get the 9" width to fit? What needs done, espeically up front? ***
If my calculations are reasonably correct...:
~ rim is 1.5" wider divided by 2 = .75" (= 20mm)
~ offset is going from stock +45 to +25 = 20mm difference
~ since the +25 offset brings the rim outward by 20mm, I think that ends up making the inner side of the new rim/tire set-up about net the same distance from the inner fender and shock housing.
~Essentially I widened the set up on the inner side by 20mm, but then pulled the rim outward 20mm, so I think it's a wash... yes????
~ What do I do with the FRONT wheel well? Can I![Smash](https://acurazine.com/forums/images/smilies/smash.gif)
the rear of the front well?
Thanks for info & advice. PLEASE correct me if I'm wrong above.
#392
I'm not specifically looking for a truck rim, just going by ones I like.
I've got 3 styles now I really like. One is 7.5", so that's easy. Other two are 8" wide........TBC....
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
#393
i saw somewhere that they weigh around that too.. really the lighter the better even if its only 3 lbs each side..
#397
anyone running a 255 45 19?? also can you provide a picture.. want to see what it looks like compared to the stock size.
RDXRonin (03-08-2015)
#399
i like the wheel pattern they look tall.. maybe cause smaller tire?? need to lower it =)
#400
looks good!, I've been trying to save up for some Black 20x10s with a 40 offset for a while now ( in college so it's hard to do haha). But interesting that you went with summer tires on it. I'm obsessed with the F10 M5 and those are to the tires that come on them and the forums have said very good things about them. They even have a warranty, which is rare for a summer tire!
