TPMS System Failure
Old Dec 23, 2008 | 12:11 PM
lindros2's Avatar
Black
TPMS System Failure
Anyone having issues with this due to cold weather?
Old Dec 23, 2008 | 04:21 PM
lilcasino's Avatar
yup, every morning 3 tires come up if the day gets warmer they'll go off. What really stinks is when you wake up to -2 degrees and 2 feet of snow and can't turn vsa off.
Old Dec 23, 2008 | 05:59 PM
littleblazer's Avatar
I put 35 lbs all four tires. is normal drop 2-3 lbs and gain 2-3 lbs.
I have Nitogen in all my tires. TPMS goes on when 29 lbs.
Old Dec 23, 2008 | 06:28 PM
stevel's Avatar
inflate them now that it's cold. pretty easy. I set mine to 36psi once it dropped below 30 degrees or so...... no warnings at all at -4........
Old Dec 24, 2008 | 06:44 PM
Carbon2008RDX's Avatar
Carbon Bronze Pearl 2008
My dealer also filled my tires with nitrogen. I have since topped them off with air to bring cold PSI to about 35. Yes, it can easily vary -3 PSI or more the colder it gets. Better to have more PSI than not enough.
Old Dec 25, 2008 | 11:23 PM
cwepruk's Avatar
I usually don't have an issue, but it has happened once and went away after 10-15 minutes on a really cold day (like -20F).
Old Jul 27, 2009 | 12:11 PM
DOGMA73's Avatar
It just happened to me yesterday. It was sunny out and quite warm. I drove up a mountain area and shortly thereafter, the "!" went on and I clicked the info and it said TPMS failure. When looking to see the tire pressure display, there was nothing showing for any of the tires, as though they did not exist. I shut off the vehicle and started it again to see if this would somehow reset the computer system, but I still had the TPMS failure display.
Shortly after I drove down to normal altitude, the warning went off by itself and all was normal. Now we don't really have much for mountains around here although I was at a much higher altitude than usual. Its the only thing I can think of that would have set off the failure warning, especially after the fact that after I decended to the usual altitude, the warning was gone.
It hasn't happened since.
Old Jul 28, 2009 | 02:17 AM
JMJ3rd's Avatar
'06 RL Tech
Ok, why the N2 in the tires? Is this only for up north?
Nevermind. Found it.
http://www.innovativebalancing.com/Nitrogen.htm
Jamus22
Jun 11, 2023 10:08 AM
neuronbob
23
Jul 16, 2019 10:48 AM
Pham Alvan
Mar 16, 2016 09:17 AM
johnalfa
Nov 5, 2015 06:44 PM
RobbDizzle
Oct 15, 2015 11:16 AM
