Strange Rattle
Old Apr 29, 2009 | 10:40 AM
AT7Driver's Avatar
Strange Rattle
My 2009 RDX has developed an intermittent rattle that seems to be coming from the drivers door panel or the seat belt post. It seems to only rattle when the brakes are applied. Any suggestions?
Old Apr 29, 2009 | 10:53 AM
MMike1981's Avatar
big shot.
sounds like you have the begining of what I am dealing with....
but, in order to further help you...the rattle that you describe is it a CREAK that is affected by gravity, or is it an actual rattle......i guess...is it affected by weight being shifted and you hear a creaking as a result or no.....it should be coming straight from the B-Pillar...
Old Apr 29, 2009 | 11:17 AM
AT7Driver's Avatar
I sure appreciate your reply and I will need to get back with you on what you asked, as it was not doing it today, thank god! I don't think its a seam creak, tho, it sounds like a tick of a clock.
Old Apr 29, 2009 | 11:20 AM
MMike1981's Avatar
big shot.
yea...totally different then....
Old May 3, 2009 | 05:16 PM
Carbon2008RDX's Avatar
Carbon Bronze Pearl 2008
Most likely it's the passenger seatbelt buckle clicking against the plastic! If you have no passenger then do an experiment and fasten the passenger seabelt anyway (ignore on screen warnings) and drive and I bet the rattle is gone! Was in my case. Annoying yes, but, not a defect.
Old May 4, 2009 | 03:21 AM
flar's Avatar
Former 07 RDX Tech owner
I sometimes find it sufficient to reverse the lay of the seatbelt against the B-pillar. If the metal buckle part is facing in then flip it out, or vice versa.
Old Dec 8, 2011 | 05:49 PM
fryrice's Avatar
i have this problem when i am going around 80mph....it sounds like coming from the front passenger side by the speakers...
mlody
Dec 4, 2019 02:11 PM
marcelft
Jul 10, 2018 06:17 PM
Robospinner
22
Sep 24, 2015 08:47 AM
jaynatlanta
5G TLX Problems & Fixes
Sep 15, 2015 11:08 AM
3GTLOwns
Sep 9, 2015 09:51 PM
