Speakers COld weather???
Old Jan 3, 2008 | 10:22 AM
Nyjumpman23's Avatar
ACURA ENTHUSIAST
Today, of course, in NYC, windchilllllllllll factor was like -8
it was 15 degrees this morning.
I started my car to warm up, and radio was nothing but static. But it was static from the speakers, like a Big FUZZ noise on all of them.
So i turned off the radio,
switched from my mp3 cd to Xm & FM channels..andit slowly cleared up.
Was this due to the cold weather? Has anyone else had this issue?
Is just seemed excessively weird. I could hear it the most on the Center speaker on the dash.
Old Jan 3, 2008 | 04:41 PM
mau108's Avatar
never heard of that. My speakers just pop upon a cold start.
Old Jan 3, 2008 | 05:09 PM
ACURA ENTHUSIAST
Next time or if it happens, I'll record the sound and post it up.
It was weird.
Id figure I'd inform you guys, just incase you get the same thing.
I'll keep you all up to date fellow Acuraziner's
Old Jan 4, 2008 | 06:21 AM
vrflyer's Avatar
Happened to me this morning (so you're not going crazy) heading to work, so I turned it off for a min. until the air was starting to blow - then the speakers "cleared" up...
BTW, it feels like 2F outside right now....
Old Jan 21, 2008 | 09:03 PM
vrflyer's Avatar
Happened again this morning, was -2F with windchill - car has been sitting out for over a week, neglected to garage it.
Old Jan 23, 2008 | 02:32 PM
ratchett's Avatar
9th Gear
You're definitely not going crazy. This has been happening to me for over a month now and I automatically equated the problem with the cold weather since the mornings when it's bitter cold I have the problem and the mornings when it's just mildly cold I don't. I guess the only cure is to either garage the vehicle or wait until the warm weather comes back. I never had that problem with my 2000 TL but the stereo systems are completely different. If anyone comes up with a solution or if I should address this to my dealer I would be happy to know. Thanks!
Old Jan 26, 2008 | 02:51 PM
kthlex's Avatar
RDX Tech - Bronze/Tuape
I have had the same exact problem this week - temp was below 10 each time. Is this something that should be taken to the dealer about?
Old Jan 26, 2008 | 05:13 PM
vrflyer's Avatar
I'd say yes & no (I'll explain)....
Yes, because supposedly the RDX is very well insulated for the avg. mid-priced CUV...
No, because electronics do not respond well to severe temps, example: look at any high end speaker disclaimer about running them in 0deg temps, etc...
I'd say this is one of those double edge sword deals (perhaps).
Old Jan 29, 2008 | 07:37 PM
PreciousBusterbird's Avatar
It is -12 (F) and I am getting static on start. I thought you were crazy and I congratulated myself on having a "better" vehicle - and then it happened!! The poor vehicle was NOT happy today. I think the MPG was around 13 and it felt like I was driving through thick mud. Everything seemed difficult. Not a happy car. I was doing short trips at <40 mph, so I don't think it ever loosened up.
I had people in my vehicle when the static started and I quickly shut off the radio, hoping no one noticed. I think they were too busy looking at the NAV screen. Later I turned the radio back on and all was OK. WHEW!
Old Jan 31, 2008 | 10:32 AM
vrflyer's Avatar
Now that's classic....
...and you probably were like this guy --->
Old Feb 5, 2008 | 11:59 AM
MN Matt's Avatar
doing the same thing
dealer is replacing radio today. 2007 tech
Old Feb 6, 2008 | 09:20 AM
MN Matt - I'm sorry - I can't tell if you are joking. Is the dealer REALLY replacing the radio??????? Which dealer do you go to? I am in MN also...
Thanks.
Old Feb 6, 2008 | 09:46 AM
Thanks.
Old Feb 6, 2008 | 05:08 PM
MN Matt's Avatar
Thanks.
White Bear Acura-- They replaced it, saying it was a warranty issue- Just picked the car up and it seems to work fine-I guess we will see when it gets cold again this weekend.
I suppose your dealer is Bloomington Acura - I think both are owned by the same group -"Luther"
Old Feb 7, 2008 | 03:21 PM
ratchett's Avatar
9th Gear
Wow!! Did the dealer pinpoint any particular problem or did they just take your word for it on the static problem? It just seems like the dealer would want to verify the problem and would have to keep my vehicle overnight on an extremely cold night to know what I was talking about. Either way, I will be interested to know if the problem occurs on your new radio. If not, I am all over my dealership about replacing my radio as well. Thanks for heads up!
Old Feb 17, 2008 | 08:05 PM
kthlex's Avatar
During my A16 service I had my service dept investigate. All they said the could do is document the problem since they were not able to reporduce it. Of course prior to their conclusion I told them that it had to sit overnight and it had to be under 15 deg.
Old Feb 17, 2008 | 10:20 PM
karrock's Avatar
08 RDX Tech Silver/Ebony
I get a good minute of static/crackle/popping/fuzz in cold weather too... Usually after the car's been sitting parked overnight and it's close to or below freezing temps.
So MN Matt -- you just walked into the dealership and they told you they were going to replace it under warranty? Anyone know if there's a TSB or something out on this, or if dealers are just replacing "as necessary" when a customer comes in reporting the problem?
Old Feb 18, 2008 | 08:50 PM
MN Matt's Avatar
Told them of the problem and they replaced the radio. They mentioned that there was a bulletin regarding this -- I did not ask to see it or read it - but they did say I was not the only one with a defective radio they have seen.
Jul 16, 2017 07:33 AM
kb1rl
Sep 30, 2015 10:17 AM
polish_pat
Sep 25, 2015 12:24 PM
