Right Headlight Flickering
Old Nov 11, 2013 | 12:10 PM
Ayu688's Avatar
Question Right Headlight Flickering
Hi All,
Recently purchased 07 RDX non tech and loving it other than gas mileage.
Question is, the right headlight flickers from time to time when turned on.
Safe to say its the ballast going?
Thanks in advance.
Old Nov 11, 2013 | 12:27 PM
it could be the igniter, ballast, or bulb!
easiest way to trouble shoot would be to swap Left bulb with Right bulb to see if problem follows.
then continue to trouble shoot with ballast and igniter, by swapping sides to see if problem follows.
Old Nov 11, 2013 | 11:25 PM
dcmodels's Avatar
Sure, this is the usual advice - but it requires removal of the front bumper on the RDX, as well as both headlights, in order to do the swaps - and the reinstallation of the headlights for testing.
And swapping the igniter is not an easy task, because the wire between the igniter and ballast runs INSIDE the headlight shell, within a very narrow passage. It took me an hour to fish it (ignitor and attached wire loom) out of a broken headlight, and into a new shell.
So if anyone has an *easy* suggestion for testing headlight components, then I am also interested.
Old Nov 12, 2013 | 11:39 AM
^thats as easy as you're going to get it. its a pain, but do-able. and will save you HUNDREDS
you're a smart man, maybe you can figure out a different way.
Old Nov 13, 2013 | 09:29 AM
Mr Marco's Avatar
Funny, thought I saw mine flicker last week...What is the dealer cost on this repair, $700???
Old Nov 15, 2013 | 07:41 PM
Ayu688's Avatar
Light officially went out. Off to the shop see what the diagnosis maybe......
Old Nov 15, 2013 | 10:53 PM
dcmodels's Avatar
Well, I was thinking more like some diagnostic tool, because I cannot believe that the dealer is going to disassemble and swap parts, in order to test the headlight parts - but perhaps when user Ayu688 reports back with a dealer diagnostic for his problem, we will know how the dealer decides which part is faulty. Guess I need to actually read the FSM diagnostic flow diagram.
Old Nov 16, 2013 | 12:00 PM
Mr Marco's Avatar
Really, anyone have an answer on the dealer price on this fix?
All I could find with dealer price quote here on AZ was:
https://acurazine.com/forums/showpos...19&postcount=8
hashbrown
Feb 18, 2022 11:20 AM
MilanoRedDashR
Oct 8, 2015 10:30 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
2Quik
Sep 23, 2015 01:03 PM
