rear wiper replacement
Old Feb 19, 2011 | 11:41 AM
JOE COOL's Avatar
someone snapped off my rear wiper.
anyone ever replace one?
i ordered the parts.arm and wiper blade.
i have a question.
i removed top nut,but below it was another metal nut.
the same one that comes encased in the replacement arm.
the one in the replacement arm is not removeable,so the one that broke off from the old arm needs to be removed.
i tried turning it both left and right ,no movement at all.didnt want to force and maybe break rear glass.
then i noticed the new metal part in the new arm is not even threaded.
what holds it on and how do i remove it?
Old Feb 19, 2011 | 01:37 PM
XLR8R's Avatar
You should not have to remove the second nut to replace the wiper arm.
There should be a bushing that rides under the wiper arm, but on top of the second nut. Did you get this bushing off with the old wiper arm? The unthreaded metal piece you describe on the new wiper arm should be the new bushing. It used to be a separate part, unless they have started welding them together.
Put the new bushing on top of the second nut, then the arm (or as a unit, if they are welded) and snug it down.
Old Feb 21, 2011 | 01:46 PM
JOE COOL's Avatar
its not a seperate part.
it comes from factory installed in arm,and it doesnt look like to can be removed,its pressure fitted.
the old nut has to be removed t give me the clearance to put the new arm on and then the top bolt.
Old Feb 23, 2011 | 10:10 AM
XLR8R's Avatar
Hmmm, maybe double check the part number. Ask a dealer if there has been a change to the design.
Old Feb 24, 2011 | 07:36 PM
JOE COOL's Avatar
fixed it yesterday.
used a vise grip to lock on to the top of the nut,and pulled it right off.
thanks for your help.
csmeance
Jan 7, 2026 06:25 PM
mada51589
Jan 9, 2025 04:40 PM
TL-Rocket
Apr 29, 2023 02:33 AM
niray9
Dec 8, 2015 07:34 PM
wilztlxs
Dec 1, 2015 09:16 AM
