Rear Damper Leaking
Old Jun 7, 2010 | 07:56 AM
737 Jock's Avatar
haole kama'a-ina
Rear Damper Leaking
The rear shock dampers have been developing leaks regularly.
This has been discussed before. However, Honda has now made a new shock damper available with a superceded part number. The old number was 52610-STK-A02 and the new number is 52610-STK-A03. You can see it at Honda-E-store or any of the on-line dealer parts stores under Chassis-Rear Shock Absorber. The damper comes with new rubber bushings.
To check your rear shocks for leaks look at the lower shaft part under the ribbed plastic cover. It should be somewhat dirty but dry. If you see greasy dirt that can be smeared and has a shine to it, the damper is leaking:
HairyMonkey019
Apr 22, 2016 10:50 PM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
IIDXholic
Oct 8, 2015 07:53 AM
Iakonafuji
Sep 21, 2015 02:39 PM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
