P0976 problem need serious help
Old 04-26-2017, 03:24 PM
9th Gear
dominiricandaone's Avatar
Hello I'm new to this forum I have recently purchased a used RDX 124k tech package.
the RDX was riding perfect for about 3k miles
as I came to a red I stopped.as the green light came I hit the gas pedal and it just felt like it was in neutral . So I put it in park and back to drive. The RDX took off as I get on to the highway about 4 miles down the engine light came on check trans came on and a flashing green D light was blinking.i finally made it home and put the scanner and pulled p0976 Shift Solenoid 'B' Control Circuit Low.
i deleted it and comes right back on about 2 seconds after it's cleared
so I took it to the dealer and they told me I need to replace the solenoid. I replace the solenoid
Started the car and no light but after a minute it came on ...So I cleared code again and put in on drive and drive around the block .The transmission shift perfect no problem. As soon as I put back up to my house and put it back on park the code comes back on.....Idk what to do anymore I'm clueless I replaced alternator thinking g it was a voltage problem battery checks out good and trans oil level is good ....I'm clueless....I also noticed a ground wire on the passenger side from the strut tower to the engine mount look like it's no good but I really don't Kno what else to do please any help is good
Old 04-26-2017, 03:31 PM
Received 8,714 Likes on 6,721 Posts
the wires connecting that solenoid may be loose/cut/chewed by a mouse. Examine it carefully
Old 04-27-2017, 11:57 AM
DRR98's Avatar
First change the ATF. Use only Honda DW-1. It may have never been changed and could cause the solenoid to stick.
If what you call a ground wire is the wheel speed sensor wire and it is broken it needs to be replaced.
Old 04-27-2017, 01:21 PM
9th Gear
Thanks for the help....I check the wire they all check out good
Old 04-27-2017, 01:23 PM
9th Gear
I changed the fluid as I replaced the sensor ....And the wire is not a speed sensor ....The wire I'm talking about is a ground on the passenger strut that connects to the engine mount
Old 04-27-2017, 01:24 PM
9th Gear
I still seem to have this problem idk why I have literally checked everything
Old 04-27-2017, 01:32 PM
Received 16,266 Likes on 11,974 Posts
did you drain and fill with new fluid?
Old 04-27-2017, 01:44 PM
9th Gear
Yes I bought 4 quarts of trans oil from Acura
Old 04-27-2017, 05:28 PM
9th Gear
I've checked continuity between the plug and also checks out fine
Old 04-27-2017, 05:46 PM
hues10's Avatar
Sounds like it is dealer time
Old 04-27-2017, 06:20 PM
9th Gear
first thing i did was take it to them and they told me i needed a sensor. to wich they gave me the part number , i ordered one off ebay and installed it and i still have the same problem
Old 04-28-2017, 02:02 PM
DRR98's Avatar
About that strut ground wire...
I just searched Brenardi Acura parts diagrams to see if I could find that part and I can't seem to find it.
What I did find are the wires that are part of the wheel speed sensor assemblies that have a mounting clip on the strut. It then goes to the wheel.
You might want to try to find the "ground wire" yourself at Brenardi.
Or go to the chassis section, then open the knuckle diagram to find the front sensor assys. that I saw.
Here are the parts I found
Fr L sensor assy pn- 57455-STK-A01 MSRP-$36.58 $26.34
Fr R sensor assy pn- 57450-STK-A01 MSRP-$36.58 $26.34
Old 04-28-2017, 04:49 PM
DRR98's Avatar
Oh, I forgot to say that if either one of those sensors fail it will mess with lots of things. One of the things is controlling the transmission shifts.
Old 04-28-2017, 08:33 PM
9th Gear
thanks for the help....the wire I was talking about is a ground and I have replaced it ....still same issue.....how ever I have another question is it possible the PCM failed ....I did noticed the PCM bolts were very loose .....the reason why I ask is because if I cleared the code and let the ignition switch on the ON position the light comes back after like 3 minutes....with the car still off ....I just don't get it I check the continuity between the wire...I've replaced the wire I replaced the fluid and still all I have left is the either the sensor is still bad or the PCM failed
Chrisdr809 (12-08-2019)
Old 12-08-2019, 06:15 PM
3rd Gear
Chrisdr809's Avatar
hello sir✋🏽
Did you ever figure out what the problem was??
Old 12-11-2019, 02:36 PM
9th Gear
Originally Posted by Chrisdr809
hello sir✋🏽
no I never did, there was a massive flood by where I live, insurance totaled it about and I got paid I am currently careless although I am looking to buy another 1g rdx
Chrisdr809 (12-11-2019)
