P0747 - Check Transmission
When I started my commute home tonight I decided to try out the Sport shift mode to see if I could get better mileage than what it is doing on its own (not high hopes, but have to try something). I shifted to S and started out - the engine got to around 3-4K and then upshifted, but with a lurch. That didn't sound right. I tried hitting a paddle to upshift again and nothing so I switched to D. It then seemed to continue in a bad gear and lurching on most of the shifts.
As I drove it seemed that it would lurch on an upshift from something like 2 to 3 and then it would lurch twice downshifting as I came to a stop. It also acted like it was in a very low gear when coming to a stop with lots of engine braking. After a few starts and stops a P0747 code showed up in diagnostics and the message was "the transmission may operate in lower gears and shift abruptly until you see your dealer. please schedule an appointment as soon as possible"
I had a highway commute home so I decided to just drive home and call the dealer tomorrow morning - it was doing about 3K on the tach at 60-65 and behaving reasonably other than feeling like it was in 3rd or 4th instead of 5th so I headed home. (FWIW, mileage was about 20MPG which was not bad considering I don't get much better than that normally.)
Grrr... 1400 miles and ready for????
The only up-side is that I'm hoping that whatever is wrong with it has also been causing my rather disappointing gas mileage so far before it went completely clunky.
That code means your AT clutch pressure control solenoid valve A is stuck on. Could be as simple as replacing the ATF but may be as bad as replacing the transmission. Most likely they will have to replace the valve. Good luck and let us know what the outcome is.
Damn, that blows.
I was disappointed to learn that sport mode tops out in 4th gear, and won't shift into 5th even at highway speeds (though you can force it into 5th manually but then you're into full manual mode). So I wouldn't expect it to help MPG if you do a lot of highway driving. On my last car, sport mode affected upshifts and downshifts, and would hold gears in corners, but still went into 5th. I used it all the time and didn't notice a gas mileage hit. Then again, my driving is biased to highway cruising where the car quickly hops into 5th gear regardless of mode. It's a pity the RDX sport mode locks out 5th gear.
Good luck on the trans issue -- I hope the fix is quick and painless. If they can access that valve through the bottom pan, then it should be fairly easy to address the problem. Keep us posted.
I was hoping that I could use it to hold lower gears more until I get to speed. One of the things I've observed is that when I need a little bit of acceleration while cruising it appears to spool up the turbo instead of downshifting - that may feel more "comfy", but it seems to eat more gas than just downshifting. Anyway, it was just the kernel of a theory and I didn't get more than 30 feet on trying it out before "CLUNK".
Also, I need to try it out in the twisties again with S mode - there I was having serious "you're in the wrong gear again dude" problems with regular Drive. Someone here mentioned that it downshifts when you brake into a corner, but my experience was that when I came off the brakes onto the gas it was caught by surprise. I did put it in S mode briefly while I was doing my twisty run, but left it in non-manual mode and the mileage went up by a couple of MPG, but the gear selection wasn't really much better for handling. I didn't want to try full manual there because the paddles are never accessible when the road is too curvy (dang hi-tech pretend-boy-racer ergonomics)...
It's at Serramonte Acura. They were going to make me wait, but the service consultant took my P0747 code back into the service bay and when she returned she immediately set me up with a loaner car(*). I hope that isn't a bad sign.
I had a little bit of trouble with her attitude. She kept talking to me like "Oh you poor child, a problem with your car? This beautiful car right here? Oh, that is so surprising, you poor thing." I imagine it might make some people feel comforted with thinking "Yeah, I thought that was kind of odd", but it felt more like "I'm pretending that we never get cars with problems so that you think Acura is a great company" and it really started grating on my nerves after a very short while. I kind of felt like saying "listen, cut the crap, let's get this car in the queue for service", but didn't want to rain on her little show. It wasn't so much "unprofessional" as it was cloying.
(*) Loaner is a white RDX Tech with black interior, 3200 miles on it and they gave me a non-remote key - grrr...
The part is on order so they'll have the car for a couple of days waiting for it...
Originally Posted by flar
Just got the call from the dealer - it seems my clutch pressure control solenoid valve needs to be replaced. Who would have guessed? Oh, wait, you did...
flare - did you get your solenoid valve replaced?
Just got my car back today - woohoo! It took them a couple of days to install the part after they got it. When I picked it up it had a "77" code from the AWD system in the diagnostic messages which sounded scary, but the voice said that the remedy was to pull over and power cycle the car and see if it went away. Since I didn't have any warning lights I'm guessing it was a temporary problem they had during one of the test drives, but it would be nice if they'd either clear it if they know that it's not an issue or let me know that it happened...
Many of the things on the steering wheel are not intended to be accessed while turning a corner so it isn't much of an issue where the buttons are when the wheel isn't in the home position.
I think you could probably say the same thing about the shift paddles, though. Ideally you would know what gear to be in before you get to the corner. With a manual car I'm usually pretty well trained as to gear selection by the time I've got a couple hundred miles on the car. With this car (it's the first AT I've ever owned), I'm in the dark so I sometimes want to change my mind during a corner. The solution is probably to drive more around the city in S-Manual mode until I get an idea of what the gearing is like before I try doing my own shifts on a twisty road...
this is old, but anyone having similar problems with their trans?
Thought it was weird how high the rpm's are in S mode on highway, but seems it is normal.
My car is starting to feel off at cruising speeds with gentle acceleration. It feels like the converter is not engaging all the way and I am getting some slipping.
When I hammer it it feels connected, just at light throttle it seems to make more noise that speed.
BTW have done all fluid changes. 3 times with 125K on clock. Last one was a few thousand miles ago.
Do you have the part number by any chance? Have the same code for my 08 Acura TL typs
do you know the part number by any chance? I have the same code for my
08 Acura TL Type S automatic
Acura RDX 2014 Check engine light
Hello,
I know this is an old post but I am having similar issues:
I have an Acura RDX 2014 base at 137k miles. Recently it has been super cold up here in Connecticut and a few weeks back there was a sudden skip or jerk sensation while the gear switched at low speed. I though this could be due to the weather and waited longer to warm the car up. This seemed to reduce the issue. However, a few days back this happened at high speed (60mph) and later that evening the check engine light went on and it said check transmission but the car was fine at high speed. The next day the same issue persisted regardless of the speed and for some reason the car was running at high RPM (4-5K) at 60mph, so I noticed this happens when the car is suddenly accelerated especially while merging into highways. I took it to an Acura dealership for diagnostics and they replaced the EL636 switch pressure and changed the transmission fluid (MA20) but the issue still didn’t get resolved. And the suggested me to change the transmission.
I went to Autozone and the error code was P0747 and P0776 and apparently the dealership said they couldn't get the code.
Thank you so much for your help in advance!
I don't really have any advice per se but couple things:
You're definitely in 3rd gear with that combo of speed and RPM. No doubt about it. Maybe mention this more explicitly the next time you have it looked at?
What is MA20? Never heard of it. The correct trans fluid for your RDX is Honda ATF-DW1. Your invoice should list part number 08200-9008. I assume the dealership would use the correct fluid but you never know.
mada51589
Jan 9, 2025 04:40 PM
HeloDown
Sep 8, 2015 06:51 PM
