Musty smell from A/C, any fixes?
mrgold35
I'm starting to get the old musty smell from the A/C unit. ![Why Me](https://acurazine.com/forums/images/smilies/whyme.gif)
I usually run the A/C system in Auto mode and change my cabin air filter each year. I don't seem to have the same problem with my TSX?
Has anyone tried the A/C flush stuff for the coils or any other remedies to kill the smell?
Copy cat shinobi
Does the smell change for better when the car is washed?
The reason I ask is because the air is drawn in just behind the hood. Sometimes after a storm I pick up the same smell. Try recirc mode for a while, does it go away? If not it may be in the vent plumbing.
Rich and Famous
mrgold35
The musty smell is not consistent. It seems it happens more on more humid days (humid days are rare in NM). I can check my vents and A/C drain hole.
I've seen in the past those A/C foam sprays to remove coil mold/mildew buildup from the condensation from humidity. I wasn't sure if it was worth doing or if there was a better fix.
Copy cat shinobi
At gas stations, that window cleaner that everyone uses while pumping gas, sometimes kids (retarded grownups) do some crazy things with that water. I make it a habit not to use those. Because any of that water seeps into the breather you get skunky air for a while. Station attendents usually do the minimal amount of work to get by, and neglect those, in some places(not all). In my case a simple car wash fixed it.
Good luck
I've been told that it can be caused by humidity being trapped in the condenser(?). It was recommended to turn the A/C off for the last couple of minutes of driving to pass fresh air through the ventilation system before turning the vehicle off. Hope this helps.
Biggie_B
02-26-2017 11:14 AM
