Lost power now vents position stuck on defrost
I replaced a sensor on my wife's 2011 RDX w/Tech and needed to clear the CEL without an OBDII scanner. I disconnected the battery for a few minutes and it took care of the light, BUT now the vent position is stuck on defrost and won't change positions! Any suggestions would be greatly appreciated!
CSmoney28
There is one located in both the passenger and driver foot wells because we have dual climate control. Check Under-Hood Primary Fuse Box for Number 9 40A Blower for a Bad Fuse to remove use a Fuse Puller and look in Fuse Window to see if it's blown. If not that issue check thread on DIY for Blend Door Actuator Fix.
CS... I think the fuse is okay because I have the blower. The blend door actuator in the driver foot well is functioning because I can actually watch it happen as I change the temperature up and down. Am I wrong in saying there should be at least three one on each side for the temperature and then one for the vent positioning?
CSmoney28
Here you go
![](https://www.acurapartswarehouse.com/resources/encry/diagram/apw/2020/small/aeba7cacccd7c125d095320724bcbbb1.png)
![](https://www.acurapartswarehouse.com/resources/encry/part-picture/hpn/small/6c52bf8667a892738ae9794501791a9b/114156977c2061177b50ea894a1b61bf.png)
- Motor Assy., Fresh/Recirculating
Ref No.: 6
Motor Assy., Air Mix (DRIVER SIDE)
Ref No.: 13
Motor Assy., Air Mix (PASSENGER SIDE)
Ref No.: 14
Motor Assy., Mode
Ref No.: 12
