Hid headlights point too low?
Old 05-01-2009 | 09:21 PM
finkosmaximus's Avatar
2009 RDX seems the low beam hid headlights seem to be pointing too low, can't see more than a couple feeet in front of the car.. is this just me? Can it be adjusted?
Old 05-03-2009 | 06:25 PM
Carbon2008RDX's Avatar
Carbon Bronze Pearl 2008
I have a 2008 RDX but I'm sure the specs for the HIDS are the same. Mine seem to aim at a proper level and sight length. Sorry, don't know how to adjust their height.
Old 05-03-2009 | 08:01 PM
ltngbg99's Avatar
We have a 2008. They have always seemed a little low. Don't know if they can be aimed a little higher.
Old 05-04-2009 | 03:02 PM
cwepruk's Avatar
If you can't see mroe than a couple feet - you likely don't have the lights turned on.
Mine are aimed a tad low, but i can still see a long ways (hundreds of feet). They can be adjusted - check the manual first, if not there, ask the dealer to aim them.
Old 05-04-2009 | 09:10 PM
BigHatch's Avatar
not an SUV ...a Big Hatch
There should be a simple screw you turn to adjust the height. Most cars are set up that way. I need to aim mine higher after having lowered it, but I've just been lazy,.
Old 05-05-2009 | 11:26 AM
phoward_15's Avatar
/\+1 Yeah there should be a screw to adjust the height. Be careful though it doesn't take a lot to move the lights up and down. Just maybe one half a turn.
Old 05-05-2009 | 12:15 PM
AltRDX's Avatar
Anyone know if the DRL can be adjusted independently? My HID headlights seem to aim fine on both sides but the passenger side DRL is pointing way higher for some reason...
Old 05-08-2009 | 12:46 PM
BigHatch's Avatar
maybe check the bulb, maybe it is crooked somehow.. otherwise i've only seen headlamps with one adjustment for the housing in the past.. maybe check any other housing mounting points to make sure they're all fastened corectly.
BoricuaTL
04-08-2016 01:08 PM
JnC
09-11-2015 06:06 AM
CaliAtenza
5G TLX Photograph Gallery
09-09-2015 06:48 PM
voigt
09-02-2015 10:44 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
Quick Reply: Hid headlights point too low?
