Front end clunk
Old Jun 10, 2023 | 08:19 PM
dzfiction's Avatar
Front end clunk
I hear a clunk when I first drive for a 100 feet then it disappears til next time I start the car again
it is a 2010 RDX
Old Sep 21, 2023 | 03:32 PM
ILCD5's Avatar
6th Gear
After I put new (aftermarket) strut assemblies on my car it makes a clunk noise when I first start driving and make a turn. I replaced the driver side under parts warranty, but it still does it. I changed the sway bar links as well so I'm pretty sure that isn't the problem.
Old Nov 29, 2024 | 03:41 PM
SouthOfGravity's Avatar
Lower motor mount: Just for the future folks, my 2010 Acura RDX has a continuous urgent metallic striking noise at takeoff, that sounding like some metallic guts were being torn out. This occurred at 'take off' [left, right, straight], and would dissipate quickly as speed was reached. During troubleshooting, I could also get it to occur if giving it heavy pedal at slow speeds during a downshift. Some, much lesser version of the noise could occur if I help the brake and hit the gas, but NOT the metallic striking noise but a bad low pitched vibration. I finally had a family member perform the 'power brake' while I lay looking underneath and I could see the 'front' u joint of the driveshaft moving completely forward to contact a cross support. Meaning, at takoff those bolts would be spinning and hitting that metal. After removing the lower motor mount you could see it was cracked in half. [picture possibly included if I figured out how] It was a $66 part at Auto store, and a 30 minute job to change with 17/19 wrench/socket and the car runs MUCH smoother in all ways now, so I assume it was failing for awhile.
mariusinseattle
Sep 21, 2024 05:30 PM
trev0006
1G RDX (2007-2012)
May 24, 2010 02:47 PM
gungho_15
1G RDX (2007-2012)
17
Sep 8, 2009 07:15 PM
metalblaze
1G RDX (2007-2012)
Aug 31, 2008 05:57 PM
