Flat Tire Or Blown Off
Old Feb 15, 2007 | 09:41 PM
Rdxowner's Avatar
Got Boost?Rdx/Base/CGP
Well..My Rdx..I Like It So Much..Sporty,Strong and has a angry good looking car..well there is more that i like bout it..but..it has a problem..Since I Got my Rdx From Oct '06,I Got 3flat tire...cost me a lot of $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$....
A Few days ago,here in montreal it has been really windy and snowy...
It was so cold that my Tire Pressure got down..The Front At The Left One..This Is CRAZY!..i wanna know if it happened to you guys too 'bout this problem..
thanks very much..
RdxOwner
Old Feb 15, 2007 | 10:02 PM
Lrpba300's Avatar
Sporty X type
thanks very much..
RdxOwner
I don't know about the flat tires, (b/c I haven't had one!) but yes, when it gets real cold, it can make the tire sensors can go low enough to show up on the display. It moved from tire, to tires day to day. Checked pressure one day cold ck'd, put in correct amount and when it warmed up again, the display of ck tires goes away.
Old Feb 24, 2007 | 05:30 PM
cose25's Avatar
do you live in a new housing development? or any construction going on around you, home/work? the past 3 flats youve had, are you replacing the tire or just patching. patching (not plugging) is an efficient way to save a good tire unless its too close to the sidewall...
temperature is very important when setting a proper tire psi. i check my tire pressure quite often -cold-(probably once a tank).
it must be getting ~bitter~ cold up there eh? to be effecting it enough for the indicator to come on. just curious, is the low tire pressure indicator on first thing in the morning? does it go away after driving or what is happening?
Old Feb 25, 2007 | 07:47 AM
Rdxowner's Avatar
Yep i live in a new housing developement on North Shore Of montreal.now im triying to not park near sidewalks or anything that can infulence to blow my tire off...lol..anywayz thanks bro
Rdxowner
TLDude876
Dec 28, 2016 03:18 PM
lland
Oct 4, 2015 04:47 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
fallacy
Sep 4, 2015 10:15 AM
