Engine/transmission Warning Message
Old Jan 3, 2008 | 01:09 PM
riley371's Avatar
8th Gear
I've got an 07 RDX TECH, purchased June 2007 in L.A. with about 7000 miles on it.
After refueling this morning w/ 91 octane, got two messages with the same Error Code of U0155. One says it is an engine issue, one says it is a transmission issue. both say acceleration may not work like it should and to go to a dealer to have it checked out. This is my first such message of its kind and first real issue w/ the car.
I made an appointment for tomorrow morning.
Anyone have a clue what's going on here? Anyone experience the same message?
Thanks!!!
Old Jan 3, 2008 | 01:19 PM
LuvMyTSX's Avatar
Is the gas cap tightened all the way? (3 clicks, I think)
Old Jan 3, 2008 | 01:33 PM
riley371's Avatar
8th Gear
well, i just made sure. previously, the green "D" on the dash signifying that i was in Drive was flashing while I was driving (on my way to work). That stopped (just drove around the parking lot at work), but I'm getting the "check emissions system" message on the dash now that stays up there.
thanks again
Old Jan 3, 2008 | 01:45 PM
LuvMyTSX's Avatar
Hmm. Unfortunately, I'm no expert on these matters, so we'll just have to wait until one comes along. I just wanted to make sure the obvious solution was taken care of. And BTW, it usually takes a couple of days, I think, for the problem with the gas tank to clear if the cap wasn't tightened all the way, so it's not an immediate thing.
Old Jan 3, 2008 | 01:50 PM
riley371's Avatar
8th Gear
cool. thanks for checking in though. i appreciate it. it's supposed to rain cats and dogs the next few days in los angeles. not dying to go to a dealership and deal w/ a loaner/rental in those conditions, but getting a stalled car in the rain wouldn't be fun either. ugh.
Old Jan 3, 2008 | 02:52 PM
LukeaTron's Avatar
Has it been shifting smoothly/correctly? Sounds like with the flashing D the transmission is trying to tell you... something.
You don't have a son named Billy that might have fallen into a well or something do you?
Old Jan 3, 2008 | 02:57 PM
riley371's Avatar
8th Gear
i've had no complaints with its driving/shifting. drove to the rose bowl on jan. 1 and cruised easily in the 80-85 range for much of drive, weaving in and around traffic ... and no, no sons named billy taking nose dives into wells.
Old Jan 3, 2008 | 03:07 PM
LukeaTron's Avatar
Well, I'm going to guess it's a sensor issue of some sort. You might not be able to tell but I'd wager your car has dialed back the performance to some extent because it's not getting reliable feedback from some sensor or other.
Old Jan 3, 2008 | 03:09 PM
riley371's Avatar
8th Gear
ok. do you think putting off getting it checked out for a few days (until, say, the dealer has loaner cars available) is harmful to the car?
Old Jan 3, 2008 | 03:14 PM
LukeaTron's Avatar
It's hard to say without knowing what the real problem is. But, if the car seems to be running fine, I'd probably feel comfortable with it. Certainly your going to want to pay extra attention to it in the meantime. If it starts acting funny I'd probably stop driving it before it decides to leave you stranded somewhere.
Old Jan 3, 2008 | 04:50 PM
mau108's Avatar
Try this, go back to a gas station, fill her up again and this time turn the gas cap 3 or more clicks.
See if it makes the error go away. It could be leak and let in excess moisture.
Old Jan 3, 2008 | 04:54 PM
mau108's Avatar
oh and use top tier fuel (shell I believe is one in the US, not sure of others but i'll guess sunoco and mobil 1)...BP is not from what I read.
Here are some you can find in NA
http://www.toptiergas.com/retailers.html
Old Jan 3, 2008 | 05:49 PM
riley371's Avatar
8th Gear
i generally put what i presume is top tier (chevron, 76) -- i used mobile this time. but i've used it before w/o incident.
Old Jan 3, 2008 | 05:55 PM
mau108's Avatar
well looks like mobil 1 is not top tier but chevron and 76 are
Old Jan 3, 2008 | 07:23 PM
TSXdawg's Avatar
I had a "check transmission" error message and took it in right away. It turned out to be a sensor in the transmission that was malfunctioning. I would take it in soon, you don't want to mess with transmission/engine problems. They should give you a courtesy car anyways so you won't be too inconvenienced.
Old Jan 3, 2008 | 07:41 PM
sasair's Avatar
I don't think that code has anything to do with the type of gas you are using. I don't have my service manual here with me to look it up.
Here is a list of the top tier gas retailers:
QuikTrip
Chevron
Conoco
Phillips
76
Shell
Entec Stations
MFA Oil Company
Kwik Trip/Kwik Star
The Somerset Refinery, Inc.
Chevron-Canada
Aloha Petroleum
Tri-Par Oil Company
Shell-Canada
Texaco
Petro-Canada
Sunoco-Canada
Old Jan 4, 2008 | 01:56 PM
riley371's Avatar
8th Gear
thanks everyone. this morning, the emissions systems light and the engine icon were all gone. i agree i should have it looked at but need to wait until i'm sure i can get a courtesy car. my local dealer was out today and i don't wanna take a rental for 3-4 days if i can avoid it.
Old Jan 4, 2008 | 04:33 PM
JMJ3rd's Avatar
'06 RL Tech
Thx for this link. Another reason for me to not use Exxon.
Old Jan 6, 2008 | 12:55 AM
737 Jock's Avatar
haole kama'a-ina
thanks again
The flashing "D" display means the transmission Power Control Module has recorded a Diagnostic Trouble Code. This is independant of the "check emissions system" message, but the two warnings could be generated by the same fault.
Since the "D" stopped flashing, it may have been a transient condition, but the transmission DTC is recorded and should be checked. The dealer can down load the DTC, and clear it, to see if it re-occurs.
Good luck, and let us know.
Old Jun 21, 2011 | 08:26 PM
mgray2's Avatar
5th Gear
Hi...today I had a transmission code pop up and the car is driving fine. I have an appointment first thing in the morning but can you tell me if your sensor was covered under the transmission warranty or if not was it very expensive?
Old Jun 22, 2011 | 03:53 PM
mgray2's Avatar
5th Gear
Well I had the 3rd gear transmission pressure switch replaced today for a whopping 410.00 plus another 100 to flush the transmission fluid? :::shaking head::: ouch!!
MilanoRedDashR
Oct 2, 2015 10:49 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
jmaxima03
Sep 27, 2015 10:22 AM
rockyboy
Sep 25, 2015 10:44 AM
TL14
Sep 24, 2015 04:37 PM
