engine hissing noise anyone ?
Old Mar 5, 2007 | 09:25 AM
rdxfirstmd's Avatar
Question engine hissing noise anyone ?
i hear a hissing noise whenever the engine is running. is it normal 'cause of the turbo ?
Old Mar 5, 2007 | 10:50 AM
oasis3582's Avatar
Yes, that is normal turbo noise.
Old Mar 6, 2007 | 05:21 PM
catnippants's Avatar
Does the 'hiss' change pitch when you rev the engine? I'd describe the turbo as more of a whirring or whine rather than a hiss. If it's just a steady hiss, I'd be thinking fuel pump. (At least that's been my experience.) Not a problem, but a normal sound.
Mike
Old Mar 6, 2007 | 09:10 PM
oasis3582's Avatar
I think the hiss is just the pressure relief/blowoff valve from the turbo.
Old Mar 7, 2007 | 05:26 AM
rdxfirstmd's Avatar
Red face high pitch hissing noise
thanks guys for explaining.
It is a high pitch hissing noise appears whenever the engine is running. After cutting off, it's still there for a while. I think it's come from the turbo.
Besides, when I put my rdx in gear from reverse/neutral, there is always a pretty loud clicking sound come from the underbody and it takes a few seconds. Is it the front differential kicked in ?
Old Mar 7, 2007 | 01:37 PM
DNPhotography's Avatar
Photographer
I also hear this clicking from time to time. What is this???
Old Mar 8, 2007 | 10:44 PM
Allanon's Avatar
Damn I hear it too and only from the front of the car in the mornings. I'm thinking it's just the cold weather affecting something but I'll bring it up when I go in for my next oil change.
Old Mar 11, 2007 | 12:14 AM
Photographer
EXACTLY when i hear it. in the mornings.
Old Mar 11, 2007 | 07:59 PM
rdxfirstmd's Avatar
It gonna click anytime when i put the gear forward from P or R. Is it from the differential, anyone ?and is it normal Sasair ?
Old Mar 12, 2007 | 03:49 AM
porsherules911's Avatar
yep im hearing the same sound too whenever I shift into D or R but I don't hear it every time.
Old Mar 12, 2007 | 08:00 AM
neo1738's Avatar
2016 MDX Adv/SHAWD
well the clicking is most likely the colder differential fluid not lubricating as well when its cold....as for the hissing usually when an engine is idle it shouldnt be hissing, is it possible something is leaking slowly and burning off? The turbo and/or blow off/recycler valve should not hiss when idling.
Yikes
May 3, 2021 04:29 PM
Feb 25, 2020 09:57 AM
snorf
Nov 4, 2019 06:44 AM
iCrap
Sep 11, 2015 06:21 PM
Mike Bertram
Sep 10, 2015 09:27 AM
