Clock adjustment
Old Jan 23, 2022 | 02:22 PM
dhldriver's Avatar
8th Gear
Clock adjustment
My clock is 2 hours fast and can’t reset in settings, I do have the navigation and reads no signal GPS….when I tried disconnecting battery and waiting 10 minutes, it did nothing to reset time
Old Jan 23, 2022 | 05:36 PM
DaIll1's Avatar
Try a search. It has been gone over with an option of how to get it set correctly
Old Jan 31, 2022 | 11:03 AM
CSmoney28's Avatar
CSmoney28
Exclamation
You can manually change it in the GPS settings
Old Mar 17, 2022 | 05:38 PM
Kdub_rdx's Avatar
4th Gear
Other ideas?
None of this has worked for me. Settings in GPS doesn't work. Battery disconnect/reconnect doesn't do anything. Any other ideas
Old Mar 17, 2022 | 05:49 PM
deepa1600's Avatar
All of you might want to try the fix on this website. I tried on my RL and it worked. It works by disconnecting both battery terminals at exactly 12:40 am/pm local time and reconnecting them at 01:00 am/pm exactly local time. Then immediately turn ignition switch to ACC position.
Old Aug 13, 2022 | 06:52 PM
schen72's Avatar
Did the clock issue ever fix itself? I thought I read in August it was supposed to fix itself. I no longer have any Acuras so I can't myself. I was just curious.
Old Aug 14, 2022 | 08:59 AM
dhldriver's Avatar
8th Gear
not yet, still is 1hr 45 mn off
Old Aug 15, 2022 | 08:48 AM
Jeff Bowyer's Avatar
August 17th .
August 17th is the date that it supposedly fixes itself
Old Aug 17, 2022 | 09:00 AM
stevem75's Avatar
8th Gear
It's AUG 17. Mine is now 40 minutes off, which is way more annoying than being 1 hour off...
Old Aug 20, 2022 | 07:22 AM
dhldriver's Avatar
8th Gear
Weird glitch
I waited till 8/18 and was able to adjust clock to proper time…haven’t tried the calendar feature yet, may take another year, lol
Old Aug 23, 2022 | 10:11 AM
Rustyrock's Avatar
Mine initially was an hour off, but finally was able to adjust it manually to get the correct time. Everything works now. Previously it wouldn’t save manually and was about 9 hours off
Old Sep 14, 2022 | 09:31 AM
Kdub_rdx's Avatar
4th Gear
Same! Ours was one hour off but manual adjustment worked (finally). Now let's see what happens with daylight savings....
Glen08RL
Sep 21, 2019 11:18 AM
Deadhorse
Aug 23, 2013 10:12 AM
08A-SPEC
Dec 8, 2009 01:34 PM
bkw
Dec 14, 2006 08:53 AM
Omarkamal
Apr 13, 2006 10:32 PM
