Check engine light and SH AWD light
I have a 2007 tech package 150000 miles, SH AWD & check engine lights are on. The dealer states Its the turbo, $5500 to replace plus labor. The car runs fine however I need my NY inspection sticker. My machanic can install a $1500 rebuilt turbo purchased online for around
$500. But there is no guarantee the problem will be solved. What else can do or check before going forward with this very expensive repair?
the check engine light is a clue or a key. if you scan the code with an OBDII reader; you WILL get the exact code and problem the car is throwing.
with this knowledge, you can then make a better informed decision...
I've had the check engine and sh-awd light when my alternator was going out on my 08 RDX with almost 150K on her. Time for a second opinion if your mechanic is just throwing parts at your vehicle. I've taken my Acura's to the dealership for an exact diagnosis and then to a 3rd party to fix for sometimes 1/2 to 2/3 the cost Acura was charging.
Billu99tl
Oct 20, 2012 07:01 PM
