Burnt syrupy smell from the engine
Old May 7, 2009 | 12:18 AM
plausible's Avatar
I was just wondering if you guys could run down a differential of what you think could be wrong. On occasion, when I have the A/C or fan on, with no vehicles in front or around me, I get this burnt syrupy smell from the A/C. This has been happening on-and-off for the past 2 weeks. I have no clue what fluid in the engine could be causing this smell. I know the smell is originating from the engine because when I roll down the windows, I don't smell it from the surrounding environment. Also, the engine temp is normal and I have about 1800 miles on RDX. Thanks everyone.
Old May 7, 2009 | 01:11 PM
phoward_15's Avatar
Could there possibly be an electrical problem with say a burning wire that could be causing the smell? Just a thought. When you lift the hood of the car while the A/C is on do you smell it coming from a specific area of the enginer?
Old May 7, 2009 | 04:33 PM
R*D*X*'s Avatar
If you turn off Fresh Air from your A/C do you still smell it?
If yes the smell is not coming from the engine, its inside your A/C blower or something.
Old May 8, 2009 | 10:02 PM
ottoman101's Avatar
Did you just buy the car? I had a burning smell when I first bought it and the dealer said it was the chemical coating they put on the engine parts to protect from corrosion. When this heats up it makes a burning smell. It goes away after a few weeks. If this is not the case, you should get it looked at.
SidhuSaaB
May 30, 2020 12:40 AM
mvidal6
ILX
Nov 14, 2015 07:43 AM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
STL TL-S
Sep 23, 2015 08:52 PM
