Bulb Replacement/Bezel Removal
Old Mar 27, 2016 | 07:27 PM
sandiego21's Avatar
Can't believe I have not been able to find/search for this or I"m really stupid. Looking on how to remove the bezel to replace the bulbs behind the map/guide, audio, etc. buttons. Nothing for a 2007 rdx. Any help would be appreciated!!
Old Mar 27, 2016 | 11:19 PM
thisischris's Avatar
I don't think it is very common for them to burn out. Do you have multiple bulbs burnt?
Old Mar 28, 2016 | 11:05 PM
sandiego21's Avatar
Thats the whole idea of me posting my question. I need to find out how to remove the bezel to replace the burned out bulb or bulbs. If I knew how many bulbs were burned out, I would have figured out my problem.
Old Mar 29, 2016 | 03:21 AM
So you have burnt out bulbs but don't know how many? I was getting at that if you have a lot of them burnt out maybe there is a fuse for them. Good luck.
Old Mar 31, 2016 | 10:42 AM
DRR98's Avatar
Start by looking at an Acura oem online parts dealers website.
Look up the parts you need to see exploded view and if the lights are individual bulbs or maybe a circuit board with led or lcd display.
Below are a couple of spots to ck (if the links work). But go through each system related to the area the lights are in to see what is needed.
http://acura.bernardiparts.com/Acura/Parts-List.aspx
http://estore.honda.com/honda/images...STK4B3710C.png
Old Apr 3, 2016 | 08:27 PM
trent_ky's Avatar
The part number for the bulbs you need (for the climate control buttons at least) is 79671-STK-A01.
I have ordered these bulbs but I also need to know how to get the dash apart to get to them.
Old Jul 4, 2016 | 06:11 AM
pdpunome's Avatar
Ill jump on this as well, want to know how to disassemble the dash. I ended up buying a complete setup just incase, but also do not know how many bulbs are needed. I have both sides for the climate out and the top right half of the nav controls out.
08 rdx tech.
Old Jul 4, 2016 | 07:03 AM
Midnight Mystery's Avatar
Null and proud of it
I also have my driver side climate control bulb burned out...
When I had work done at the dealer, I asked how much would it cost to have it replaced...
They quoted me at $165 I think...
I don't need it that bad, 07 RDX tech...
I have no idea of what has to come off to get to those bulbs but it looks like a lot of work...
For you, hopefully it's a fuse that's easy to get to but I doubt it...
Old Jul 5, 2016 | 07:20 AM
pdpunome's Avatar
How many bulbs total for the two sides of climate controls and anyone know about the navigition controls in the middle of the climate controls. My upper right few buttons do not light up, so curious is there bulbs in there since 3/4 are still lit.
Old Jul 5, 2016 | 11:42 AM
trent_ky's Avatar
https://www.dropbox.com/s/nobxnzcf8w...ANUAL.pdf?dl=0
Basically you have to remove the passenger defrost vent and then the silver trim that runs horizontal on the dash. Then you remove the silver pieces on each side of the nav screen. All of those pieces are held on by clips. There are two bolts under the small silver pieces by the screen then the whole vent and button assembly will pop out. If I remember correctly there are three bulbs in each group of climate control buttons.
Old Oct 26, 2022 | 12:56 PM
JoWeJC's Avatar
I know old thread here but has anyone replaced these bulbs? I have a few out & I think I'll just replace them all if anyone can tell me where to get the bulbs cheep these days. Maybe ebay? I'll replace with either LED or regular, whatever is the cheapest option.
Also, I have the 2011 model.
rockstar143
Mar 26, 2023 11:13 PM
Skirmich
1/2G MDX (2001-2013)
28
Feb 8, 2016 03:38 PM
