Brake system light
Old Jan 11, 2008 | 11:08 AM
Acuraboy7's Avatar
Don't jive my 3.5
Brake system light
We have an RDX in the family now, and after 6 months and 2,700 miles which isn't alot we have had a ton of problems with the brake system light coming on. The dealer has replaced several parts to try and fix this problem, it seems to work for a while then the system light seems to come back on. Anyone else with this problem? Also to note this is about the 4th time now.
Old Jan 11, 2008 | 01:06 PM
mau108's Avatar
what exactly did they replace? List them all and we'll see whats going on.
Old Jan 11, 2008 | 04:16 PM
Acuraboy7's Avatar
Don't jive my 3.5
First time: replaced the Check Valves on the Brake boosters...
2nd: Parking Brake switch...
3rd: found nothing
4th: found nothing "light went off"
5th: Replaced the booster asbmly
If it goes on again this will be the last payment I make on the car cuz I'm going to trade it in or lemon law it...
Old Jan 11, 2008 | 04:26 PM
Tripp11's Avatar
Newbie for Life
Have you involved Acura Client Services yet? If not, start today and start documenting everything (i.e. emails, faxes, phone calls, dates, times, etc...).
1-800-382-2238
Old Jan 11, 2008 | 04:31 PM
Acuraboy7's Avatar
Don't jive my 3.5
1-800-382-2238
I'm good thanks, trust me its not the first time I've had Acura take a car back.
Old Jan 11, 2008 | 05:36 PM
mau108's Avatar
did they and you check your brake fluid level?
Old Jan 11, 2008 | 09:42 PM
Acura Technician
I would think it's a vacuum problem, possibly with the electric pump.Hopefully they fixed it.
There is a service bulletin for 07's requiring a software update
Service Bulletin
© 2006 American Honda Motor Co., Inc. – All Rights Reserved BTB 33806 (0612) 1 of 1
CLIENT INFORMATION: The information in this bulletin is intended for use only by skilled technicians who have the proper tools, equipment, and
training to correctly and safely maintain your vehicle. These procedures should not be attempted by “do-it-yourselfers,” and you should not assume this
bulletin applies to your vehicle, or that your vehicle has the condition described. To determine whether this information applies, contact an authorized
Acura automobile dealer.
December 1, 2006
06-052
Applies To: 2007 RDX – From VIN 5J8TB....7A000001 thru 5J8TB....7A008495
Brake Warning Light Is On
SYMPTOM
The amber colored brake system indicator is on, and
PGM-FI DTC P1131 (electric vacuum pump system
related PGM-FI sensor signal malfunction) is stored.
PROBABLE CAUSE
An error in the brake system software.
Normally, DTC P1131 is stored only when a PGM-FI
DTC has also been stored for one of these sensors:
• MAP sensor
• BARO sensor
• Vehicle speed sensor
• APP sensor (accelerator pedal position sensor)
CORRECTIVE ACTION
Use the HDS (with software version 2.006.019 or later)
to update the PCM PGM-FI software. Refer to service
bulletin 01–026 Updating the ECM/PCM.
SOFTWARE INFORMATION
HDS Software Version 2.006.019 (or later).
WARRANTY CLAIM INFORMATION
In warranty: The normal warranty applies.
Operation Number: 125517
Flat Rate Time: 0.3 hour
Failed Part: P/N 37820-RWC-A54
Defect Code: 03214
Symptom Code: 03205
Template ID: 06-052A
Skill Level: Repair Technician
Out of warranty: Any repair performed after warranty
expiration may be eligible for goodwill consideration by
the District Parts and Service Manager or your Zone
Office. You must request consideration, and get a
decision, before starting work.
DIAGNOSIS
Check for other PGM-FI DTCs with the HDS.
Are any other DTCs stored?
YES - Go to the indicated DTC’s troubleshooting.
NO - Go to the REPAIR PROCEDURE.
REPAIR PROCEDURE
Update the PCM/PGM-FI software using HDS software
version 2.006.019 or later. Refer to Acura service
bulletin 01-026, Updating the ECM/PCM.
PGM-FI PROGRAM ID PGM-FI PROGRAM P/N
WCA550 (or later) 37850-RWC-A55 (or later)
Old Jan 12, 2008 | 12:43 PM
Acuraboy7's Avatar
Don't jive my 3.5
Yes.
Old Jan 14, 2008 | 11:53 AM
Acuraboy7's Avatar
Don't jive my 3.5
The light is back on "say good bye old woman"
Old Jan 14, 2008 | 01:37 PM
PR RDX's Avatar
Just sent you a PM with the info. In My Wife's RDX, the problem was solved after they repaleced the MAP sensor.
William
Old Jan 14, 2008 | 03:23 PM
Acuraboy7's Avatar
Don't jive my 3.5
I'm going to file a lemon law on the car, this has gone on too long now.
Old Jan 14, 2008 | 04:36 PM
Tripp11's Avatar
Newbie for Life
If that's the case, I would quit by Honda products if I were you.
Old Jan 14, 2008 | 05:28 PM
mau108's Avatar
did you see if it could be the software update sonomaa posted?
Old Jan 14, 2008 | 11:50 PM
Acuraboy7's Avatar
Don't jive my 3.5
It could happen to any car make, doesn't mean I'dstop buying Acuras.
Old Jan 14, 2008 | 11:52 PM
Acuraboy7's Avatar
Don't jive my 3.5
If thats it why don't they know about it. thats not right, they have torn apart the car now. thats not right with only 3K on it and beening 6 months owned
Old Jan 15, 2008 | 04:44 PM
mau108's Avatar
time to find a new dealership/service shop if they don't know about simple tsb's.
Old Jan 15, 2008 | 07:50 PM
Acuraboy7's Avatar
Don't jive my 3.5
Well I think they did the computer service upgrade, my problem is something else. they have been a good dealer so far no real problems, at times they are a little pissy about giving out loaners.
Old Jan 16, 2008 | 10:11 AM
PR RDX's Avatar
I experienced the same thing as you. Dealer reflashed the software and the problem persisted. For some reason they decided to run some test on the MAP sensor. They found irregular readings and decided to repalce it. Strangely enough by replacing the MAP they fixed the Brake System Light Problem.
I'm going to look for the service records to see if they listed somekind of code or something that might help.
William
Old Jan 27, 2008 | 01:20 PM
Acuraboy7's Avatar
Don't jive my 3.5
They have a had the car for almost 2 yeeks now, its still not fixed. sorry I ment to give you guys an update but didn't really have anything to report.
Old Feb 1, 2008 | 04:20 PM
Acuraboy7's Avatar
Don't jive my 3.5
Well i picked up the car Monday after work, only to take it back Tuesday afternoon with the Brake system light on again! When i got it back Monday they told me they replaced the other check valves. They also put over 300 miles on it while they had it! well its now Friday and I picked it up again after work this time they replaced the computer system. lets see how it goes. Even so I'm going to lemon law it, they have just riped it apart too much for me. it also only has 3500 miles on it and its 6 months old. Thats too much work to have done on a car so new.
Old Feb 4, 2008 | 11:16 AM
Acuraboy7's Avatar
Don't jive my 3.5
Well its monday again, and I hate to report that the light is on again! gee maybe they will replace a knob on the radio and see if that works duh duh duh!
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
