2010 Rdx tailgate problem
Old Dec 30, 2016 | 03:55 PM
Retired Ron's Avatar
Disassembled the entire rear hatch and checked all componets with ohm meter and jumped the latch when closed and all works. Handle switch does close from open to closed via ohm meter. Acura dealer sent me a relay, but where they said it goes their is the Power Window relay, the fuel pump relay and the cut relay. no tailgate relay printed on fuse block. The relay mounted in the drivers side rear panel under an access panel is not the same #. I swapped it anyway and nothing changed so I put back the old one. Any Ideas?
F1flagger
1G RDX (2007-2012)
Oct 16, 2016 04:19 PM
sixsixfour
Oct 14, 2016 07:29 AM
chupp
2G RDX Performance Parts & Modifications
Oct 8, 2016 12:38 PM
Joel108
Oct 6, 2016 11:23 AM
