a turbo blanket, blanket or covers the turbo and keeps heat away from main components...
the way Honda implemented the turbo on the RDX; close to components without any real space will make it hard to find a blanket that does it's job
I would be interested in a turbo blanket but I have never even heard of someone mention that on this forum to be completely honest. You’ll definitely be the first person to attempt something like that right now. I never even heard of someone wrapping any part of the exhaust with the heat wrap either. I’m interested so keep me posted.
This one was bought off Amazon. I tried others but they didn't fit. Better than nothing I guess.
I don't recommend leaving the stock one on with an aftermarket DP unless you have the 3rd bolt fastened. Just having 2 bolts will cause bad vibrations and may crack the turbo housing like mine did.
The blanket was cheap. I had to get some wire to mount it.
I also had to protect the firewall and A/C lines since the A/C was not blowing cold as it should and the firewall material was coming apart.
