TMIC R&D by ETS
#203
PM me if you need a reply
Received mine today. A couple notes:
-RTV silicone is needed for the BPV.
-An extra M10 bolt is needed for the Map sensor. The stock bolt is M8, but ETS tapped an M10 hole which is nice so it will be the same size as the other bolts.
-Remove the couplers with the stock TMIC, then put them on the ETS TMIC before installing.
Unpacked
Swapped parts
Installed
Unpacked
Swapped parts
Installed
#208
I cut a hole for the taller Turbosmart BPV but realized that might be bad for the air flowing to the intercooler so I covered it up.
I'm thinking about cutting off the honeycomb area for less air restriction but I think it helps the air flow through and not around the TMIC. It could use some foam tape or rubber on the edges where there is a gap between the cover and intercooler though.
Yesterday I had a SH-AWD CEL and it went into limp mode. Not sure what that was all about. I don't see any leaks but I don't have a boost gauge (we need a boost gauge DIY btw). I'll have to diagnose that along with my squeaky pulley issue.
To be honest I have not noticed a difference. I haven't timed or dyno'd any runs though.
Yes:
http://www.extremeturbosystems.com/R...Top-Mount.html
Last edited by InfamousJamous; 04-08-2012 at 03:23 PM. Reason: Added reply to post from exist12, DeEjAy_LiM
dr427 (02-17-2013)
#214
not an SUV ...a Big Hatch
any real fitment issues? IJ noted:
"An extra M10 bolt is needed for the Map sensor. The stock bolt is M8, but ETS tapped an M10 hole which is nice so it will be the same size as the other bolts."
#215
I need to do it again this weekend as I install it on my lunch break.
They came with extra washer - the M10 hole was there - same bolt as your stock bpv.
You can get it in lowes or Home depot.
I had an extra one handy.
BigHatch (04-11-2012)
#217
has anyone tried these with hondata reflash to see if there is any problem or gain ??? also when is the next group buy put me down for number one on the list for the next group buy.
#218
Hey guys, i just installed mine on thurs and have nothing but problems so far. i thought it was a break in period..when i would drive the car would shift pretty rough and today when i went to accelerate from a stop to get on the interstate all of a sudden acceleration stopped and the car jerked back and forth and my vsa light started flashing and i could get the car to go. turned the car off and the vsa light stayed off and could drive gently but when i slightly accelerated it felt like it lost all power and the vsa came on again..kinda scarying me so im going to put the stock intercooler back in tomorrow..any ideas what this could be? i also have a weapon r intake and ecu reflash
#219
Make sure everything is tight and secure. Also the bpv adapter part.
Did you use Hondabond? I used the Permatex (High temp version)
Make sure both base are clean before applying on the Permatex.
I had the weapon R intake because and had Weapon R make the intake pipe shorter because I was throwing a code with it on.
I had the ETS TMIC with the exhaust for about a week and love it.
Just need a piggyback system to be able to tune the car and mods.
#221
Just installed mine besides dropping the MAP sensor into the black hole of the engine compartment (removed filter, air intake, and battery to find it with a few curse words during the search) it was relatively pain free. Only drove it for a trip to the mall so far, butt dyno says that there seems to be a bit more kick.
oulaw29
08-09-2013 11:14 AM
RDX_NRG
1G RDX Tires, Wheels & Suspension
09-19-2012 01:57 PM
