View Poll Results: do i send in my turbo for upgrade? 1-2 weeks down time T20 billet wheel $300-600 cost
YES do it, do it now
93.75%
no your crazy it cant be done
6.25%
Voters: 16. You may not vote on this poll
pull the trigger???
Old Jul 14, 2014 | 01:56 PM
TheWrench116's Avatar
FLETCH
Question pull the trigger???
do I go ahead and get them to do it? mike says between 30-50 whp with a T20 billet compressor wheel and $300-600 for the rebuild 1-2 weeks down time. vote now.
Old Jul 14, 2014 | 02:04 PM
bluecarbonfiber's Avatar
WTF?
cant go wrong with upgraded turbo option.. if you do it post a video of before and after..
Old Jul 14, 2014 | 06:10 PM
dresx's Avatar
You sure it's a t20? Isn't that a Garrett turbo? And I think it's smaller, maybe. Is double check the upgrade. 18t, 19t, 20g dunno what they are offering you, but research it first. I vote upgrade, but make a good choice.
Old Jul 14, 2014 | 10:10 PM
WTF?
18t was what ive been eyeing been told the 19t would need more work
Old Jul 15, 2014 | 10:33 PM
protoRDX's Avatar
Nope, our turbo is a unique version of Mitsubishi TD04-15T turbo.
AFAIK, t18 wheel can be transplanted into our turbo. I highly doubt you can do this with t20.
Old Jul 17, 2014 | 12:45 AM
ivan_baez's Avatar
I would say go for it, the gains should be noticeable, even with the stock turbo levels. I've been looking into that, but need to get my hands on a used spare RDX turbocharger to tear it apart and see what compressor wheel actually can be fit in there.
My intention is to swap only a larger compressor wheel so it can be plug&play, the exhaust side would be all right once the bypass is activated at high RPM.
Old Jul 17, 2014 | 08:56 AM
exist12's Avatar
what about an adapter plate to fit a larger turbo?
Old Jul 17, 2014 | 12:04 PM
protoRDX's Avatar
what are we going to do with variable flow valve in this case?
Old Jul 17, 2014 | 12:14 PM
exist12's Avatar
get rid of it
Old Jul 17, 2014 | 02:15 PM
protoRDX's Avatar
get rid of it
And get a bunch of CELs?
VFT was designed to create a descent torque in the mid revs range.
With bigger turbo and 2.3l engine your peak torque will further into high revs range. This will create a very noticeable turbo lag. You'll need more exhaust gases coming out to spin this turbo before you get positive spool.
Just think how often do you rev up your RDX?!
Old Jul 17, 2014 | 02:38 PM
exist12's Avatar
nope. it is just an internal waste gate(mechanical trap door)
Old Jul 17, 2014 | 03:57 PM
protoRDX's Avatar
Can you please explain your point?
How are supposed to get rid of VF actuator that is controlled by the ECU without getting the CEL?
Old Jul 17, 2014 | 07:40 PM
KenB350z's Avatar
If Bisimoto can make a 550+ CRZ, I think we can get away with an upgraded turbo. Maybe we should contact him!?!?
Old Jul 17, 2014 | 09:03 PM
protoRDX's Avatar
Bisi worked with a non-stock ECU. And he got it professionally tuned. This job costs crazy money.
Old Jul 17, 2014 | 09:08 PM
KenB350z's Avatar
We have a non-stock ecu, and can get ours professionally tuned.
Old Jul 17, 2014 | 09:11 PM
KenB350z's Avatar
Plus he is the professional that tuned it, that's why I said we should call him.
Old Jul 17, 2014 | 11:01 PM
protoRDX's Avatar
We dont need that for getting 300-330 hps on the wheels out of our powerplant.
However, I dont think getting something bigger than those numbers is a smart idea as the only option for a tranny is our 5spd AT. Which has its own limits.
+ Dont forget about our rear differential, that will need to handle 50-70% more torque. Its already not as tough as Evo's rear diff. And you are going to push it to its max capabilities with all those mods you are going to install and tune in your car.
Imho, our healthy limits are 300-320hps (on the wheels), 320-340 lb/ft torque.
With all due respect (and I do have a ton of it for what you are doing), the biggest issue still has not been targeted in your project. Cooling down the air intake temp. Just working on this issue can give you additional 10-15 hps (if not more). Getting our IAT below 45-50C will allow tuners to tune the whole setup more aggressively and more safely.
Old Jul 17, 2014 | 11:28 PM
KenB350z's Avatar
Yeah, was just inputting for the post. Me personally, I have no interest in going beyond stock turbo or stock turbo upgrade. The tranny was a big concern with my mechanic also. I think a TMIC and tuner will be good for me.
Old Jul 21, 2014 | 09:16 AM
FLETCH
SO after datalogging my drag strip runs I have conclusive evidence that the stock turbo has definite limits it just runs out of boost on the top end we are lucky if we are seeing 10 PSI
Old Jul 27, 2014 | 08:34 AM
KenB350z's Avatar
Wow, are you tuned?
Old Jul 28, 2014 | 12:36 PM
FLETCH
yes ken im tuned but not by someone I would consider competent with flashpro or hondata in general. added fuel and 1 degree of timing that was it. im thinking I should go visit another shop...
Old Jul 28, 2014 | 02:53 PM
KenB350z's Avatar
Oh ok.
Jamus22
Jun 11, 2023 10:08 AM
08KBP_VA
Oct 22, 2019 01:55 PM
adrian_s2k
1G RDX (2007-2012)
23
Jan 12, 2016 04:25 PM
Skirmich
Oct 1, 2015 12:59 PM
Eggs999bacon
Sep 24, 2015 10:08 AM
