Performance Mod Ideas - Discuss
Old Jun 6, 2012 | 08:47 AM
DRR98's Avatar
Muffler bypass valve- n/c valve between inlet and pass side outlet. Open using vtec relay. (between #9 & 5 below)
Vented RR bumper cover- #19 below is solid. Remove mtl to open inside the cross hatch grill areas to allow better heat venting and air flow.
My i/c picks up bugs, weeds, etc and I clean it often. Need a light wt, easy to clean pre-filter to clip on the inlet guide.(#18)
The spaceinside #18 is bigger than it looks, and could house two small pre-coolers. Using the window wash tk and pumping ice water. Controled by vtec relay.
Old Jun 6, 2012 | 12:11 PM
BigHatch's Avatar
not an SUV ...a Big Hatch
this last idea might be better off at low RPM.
definitely alot to make it happen too. Why not just get an intercooler water spray. MRT had some simmilar to STi type stuff... sure there's other brands out there.
Old Jun 6, 2012 | 02:23 PM
DRR98's Avatar
Hey BH,
It does get heat soaked going slow in traffic or idling. I saw iat 156f last week while idling 5 min with a/c on.
For the pre-coolers you would need air moving across them to function. You are always moving air at vtec.
Has anyone tried an RDX w/sprayer? Results?
I know some rain water gets up to our i/c, but not sure about wetting it with intent. Not wanting to scale up the fins. Distilled water maybe?
Thanks for thinking about these.
Old Jun 6, 2012 | 04:20 PM
BigHatch's Avatar
yeah, it should always be distilled water.
Never saw any signs of buildup/issues using distilled in the 06 STi i had previously.
A plus to this type of system is you can use it at will...at launch, high RPM, or push to pass!! hahah.. ok, so it's not F1 DRS and KERS.. ;p
Old Jun 27, 2012 | 11:47 PM
phuynh3's Avatar
I'm sure performance modding of the RDX will require a lot of custom fab work since there isn't a big aftermarket market for it. Although it is a k series engine so i'm sure you can make parts fit from the RSX-S or 06+ Civic Si work with the RDX.
Example would be using a RBC intake manifold and route intercooler piping to make a front mount intercooler work.
Old Jun 28, 2012 | 08:22 AM
exist12's Avatar
I still think we could make the kpro work with it running as a dual ecu.
Old Jun 28, 2012 | 10:32 AM
phuynh3's Avatar
Yeah, I agree. Flash pro would be the best bet if hondata were ever to come out with one. This would allow a lot of potential of modding the RDX. The only thing is i'm not sure how strong the k23a1 is and how well the transmission, transfer case and rear diff would handle all the power and torque if the car could reach those levels.
Old Jun 28, 2012 | 10:45 AM
exist12's Avatar
As with all hondas the transmissions would probably be the limiting factor.
Old Oct 1, 2012 | 10:08 PM
4JDM's Avatar
3rd Gear
^ Agreed!
oo7spy
Jun 19, 2023 12:48 AM
Feb 25, 2020 09:57 AM
dom
Sports Talk & Fantasy Leagues
2032
Feb 10, 2016 01:47 PM
Rcelestino93
Sep 11, 2015 12:15 PM
