New Wheels for my RDX
Old 03-07-2009, 07:14 PM
jw_snowman's Avatar
I'm looking at a couple sets of wheels for my '09 RDX Tech. I've pretty much narrowed it down to two sets but I'm not sure of the offsets that are the best. I believe the RDX offset is +40 but I'm not 100% sure on this. Any help would be appreciated. The first two sizes in the list are the same wheel, just different dimensions and I know the third will work on a CR-V so it should work on my RDX. So my only real question really is, is +55 offset too high for an RDX?
- 18x7.5, +55, 5x114.3
-18x8, +50, 5x114.3
-19x7.5, +50, 5x114.3
Old 03-07-2009, 09:15 PM
cwepruk's Avatar
55 will probbaly work without issues, but it would be ugly as hell IMO. Being that the stock rims do not stick out nearly enough, getting something with a higher offset will just make that worse.
I went with an 18x8 with a 35mm offset.
Old 03-09-2009, 10:24 PM
jw_snowman's Avatar
Yeah that's what I figured. Just thought I'd check around. The +50 looks fine on a CR-V though so I don't see why the +50 would look too bad on the RDX.
What sidewall size did you go with on your new wheels? Or are those the stockers?
Old 03-23-2009, 06:45 PM
ADAMnQuickRDX's Avatar
+40 offset and 275/40-20 Tires...wont rub, even if lowered.
I've got just the set for you...asking $1200....like new, no damage and tires show no wear!
If interested hit me at infiniteparts77@aol.com
Thanks!
Old 05-05-2009, 11:15 PM
datnvan's Avatar
stock offset is +45. why would you want to do 18"? here's mine i just got MSR 093's in 20x8.5 +40 on 255/45/20 yokohama spec-X
rockyboy
12-06-2022 02:29 PM
rseb4agze
05-03-2016 07:41 AM
ThermonMermon
09-22-2015 03:36 PM
Quick Reply: New Wheels for my RDX
