New Wheels for my RDX
I'm looking at a couple sets of wheels for my '09 RDX Tech. I've pretty much narrowed it down to two sets but I'm not sure of the offsets that are the best. I believe the RDX offset is +40 but I'm not 100% sure on this. Any help would be appreciated. The first two sizes in the list are the same wheel, just different dimensions and I know the third will work on a CR-V so it should work on my RDX. So my only real question really is, is +55 offset too high for an RDX?
- 18x7.5, +55, 5x114.3
-18x8, +50, 5x114.3
-19x7.5, +50, 5x114.3
-18x8, +50, 5x114.3
55 will probbaly work without issues, but it would be ugly as hell IMO. Being that the stock rims do not stick out nearly enough, getting something with a higher offset will just make that worse.
I went with an 18x8 with a 35mm offset.
Yeah that's what I figured. Just thought I'd check around. The +50 looks fine on a CR-V though so I don't see why the +50 would look too bad on the RDX.
What sidewall size did you go with on your new wheels? Or are those the stockers?
+40 offset and 275/40-20 Tires...wont rub, even if lowered.
I've got just the set for you...asking $1200....like new, no damage and tires show no wear!
If interested hit me at infiniteparts77@aol.com
Thanks!
Thanks!
rockyboy
12-06-2022 02:29 PM
rockyboy
01-25-2016 06:00 PM
