My mechanic laughed at the turbo when viewing the boost on his laptop via flashpro. I wasn't even a 1/4 throttle and it was about 8-10psi... We need a bigger turbo RDX family!! Maybe someone can get a group buy together for a turbo manufacturer to build one for our car?!?!
some may be due to the variable turbine inlet too... but still!
Yeah, would like that boost to come later in the power band.
Originally Posted by KenB350z
(Post 15079220)
Ken: I may have missed it...but how many miles are on your motor?
I have about 111k
(Post 15079165)
1) isn't this how a variable flow turbo supposed to work? 2) who from manufacturers will possibly get involved in a custom turbo development with a possible market of max 50-70 enthusiasts?! 3) even if we get a bigger turbo, how do we fool the variable flow valve actuator? This thing is controlled by the ECU. |
The variable flow is essential just a wastegate.
Seems if the proper tables are available for tuners, you can eliminate the variable flow element altogether and slap an externally gated turbo on there. IF
I like the instant boost I wish it would carry further through the rpm range that's my only complaint which is why I'm getting blouch performance turbo to put a bigger wheel on the compressor side of my factory setup. they led me to believe with the supporting fuel and exhaust mods it would be good for between 35-55 horses... the only thing im missing is cams and a fuel pump ( I was told nothing would fit when I was buying my list )
Originally Posted by TheWrench116
(Post 15079884)
I'm going to try and get a charge pipe made at Humble Performance.
guess some more pics are in order
(Post 15079889)
Yeah, I'm just trying to run mid 13's and I'm good. I currently own a bakery with my wife and the RDX is one of the delivery vehicles, so I don't want to do to much to it. Just mid 13's and I'm good.
How much power do you expect to make? |
Hard to say the Hp numbers, I'm hoping in the 300's.
Originally Posted by dresx
(Post 15079976)
13s should be doable. wrx guys with tdo4l-13t run mid to high 13s.
rdx 2008 SHawd with nav curb weight 3964 + m F.A. 178 = 2Tons + ...
__________________________________________________ _________ needs " MORE POWER " thanks for that Tim. your welcome Al. |
damn I wish I could pull those numbers for driving around.
(Post 15079954)
(Post 15079970)
that's insane!
And this is with a basic tune? |
Guys, this is not insane. These are incorrect numbers due to bigger injectors. The ECU calculates avg fuel cons based on the stock injectors bandwidth.
If you check it manually you'll still get same old 20-22-23 mpgs. |
Originally Posted by protoRDX
(Post 15080452)
oh ok now I feel better... jeez that's what mine shows too.
hmmm.. well then if thats the case.. i am curious on if the tank was filled prior cause if i do 167 miles with a 50/50 hwy/street driving i would be at or below a half a tank..
(Post 15080076)
WRX weighs 300 kgs less than RDX. + manual tranny
Originally Posted by bluecarbonfiber
(Post 15080704)
(Post 15080806)
I had a full tank before leaving Oklahoma City and that was the end result. I'm sure it will be another story after it's tuned.
I was traveling 75-80, the average on the tech was 50. probably run a little lean, not sure.
im sure you are pretty lean.. you still havent gunned it yet i am guessing till you get your tune..
your next fill up you should do the actual calculation just to see how close the mpg matches.. im sure its closer to 30.. specially if you did a 150 miles in a quarter of a tank |
What an awesome day, took the RDX in for a recheck of the valve and got to take the mechanic's 600hp Tundra!
http://i174.photobucket.com/albums/w...ps297bd0d6.jpg |
(Post 15080935)
So the engine is still strong at 111k miles. That is awesome.
I get about 340 out of a tank if I stay out of it but its so hard to keep out of boost when it just screams. I think im going to get a take home car from work so I can get the turbo done. see what ill get out of that. what P# is the in tank pump and was that a pita to install?
I've had mine still read over 3/4 after 150+ miles...gauge goes down slower at first. My first 1/4 might be 150 but my last 1/4 could be under 100. If I recall right on that tank I got a hair over 400 miles before filling up, between 24 and 25 mpg. Keep in mind I'm FWD...even if it's not the indicated 30+, if you can average 25 on a full tank with AWD it's still quite an accomplishment.
I think it's safe to say everyone here is dying for a tuned dyno run :thumbsup:
(Post 15081089)
Give me till tomorrow for updates on the pump, the DW200 looks a bit taller then OEM. Our pump looks more like the DW65c. I'll post as soon as I get back from there. http://i174.photobucket.com/albums/w...psdb68ec97.jpg |
