Originally Posted by wspy
(Post 15322956)
Oh
So here is my interpretation of this post:
Before you start to work on turbo you need to already have either downpipe 3" or full exhaust 2.5-3". Additionally you heed to have either FMIC or air-to-liquid IC installed. So this turbo setup consist of original bored hot side, adapter and Garrett GT2860RS. On the photos you can see how hot side is attached to adapter and how adapter is attached to cartridge. Which means Variable Flow will still be working and both solenoids are still there. There are mounts for solenoids on the cold side. This should be installed on the OEM exhaust manifold. What has to be changed/adjusted: 1) Oil feeding: has to be switched to flex feeding and fitting for the original Garrett restrictor 0.9 mm as its a ball bearing turbo. 2) Oil discharge: original Garrett oil discharge should be installed. Original hose can be used or you can switch to a braided one. 3) Coolant feed/discharge: Garrett specific banjo bolts should be used along with fittings. 4) Important: do not forget to use heat shields for all sealings, hoses and pipes. 5) Intake pipe from the IC must be relocated 2 cm closer to the driver side since the 2860 cartridge is longer than the OEM one. Plus, additionally you need to weld 2 nipples (4mm) for variable flow solenoids air supply. ...to be continued |
(Post 15322854)
The Macan and the Cayenne are the same right?
Originally Posted by protoRDX
(Post 15323751)
Macan is based on the Audi Q5 platform while Cayenne is based on the WV Tuareg platform.
(Post 15323748)
Before you start to work on turbo you need to already have either downpipe 3" or full exhaust 2.5-3". Additionally you heed to have either FMIC or air-to-liquid IC installed. So this turbo setup consist of original bored hot side, adapter and Garrett GT2860RS. On the photos you can see how hot side is attached to adapter and how adapter is attached to cartridge. Which means Variable Flow will still be working and both solenoids are still there. There are mounts for solenoids on the cold side. This should be installed on the OEM exhaust manifold. What has to be changed/adjusted: 1) Oil feeding: has to be switched to flex feeding and fitting for the original Garrett restrictor 0.9 mm as its a ball bearing turbo. 2) Oil discharge: original Garrett oil discharge should be installed. Original hose can be used or you can switch to a braided one. 3) Coolant feed/discharge: Garrett specific banjo bolts should be used along with fittings. 4) Important: do not forget to use heat shields for all sealings, hoses and pipes. 5) Intake pipe from the IC must be relocated 2 cm closer to the driver side since the 2860 cartridge is longer than the OEM one. Plus, additionally you need to weld 2 nipples (4mm) for variable flow solenoids air supply. ...to be continued I don't know about all that, but I will keep you posted on what we come up with. Still talking with BIG companies about a turbo kit. |
Originally Posted by KenB350z
(Post 15323967)
(Post 15321537)
I don't know what my car is capable of, but I made 280hp a not so good tune. But now I am with Vitviper, so we will see what happens next.
Hahaha your in for some crazy numbers. Im getting his tune just with a intake for now. Going to do injectors and Downpipe in 1 shot and just do 1 retune. Can't wait to see what vit pulls out of it. How's your tranny been holding up? Just normal fluid changes? |
Originally Posted by rdxchris710
(Post 15323985)
Awesome man. That gt28 hybrid seems bad ass.. I wonder how the ecu is going to like crazy boost. Just have to wait and see I guess.
Yep. I see good stuff for us in the future! |
(Post 15323986)
I'm on my ninth data log with them. I haven't had the chance to test out the current tune, due to all the R&D stuff going on now. But, so far it's all been good tunes for me. I can't wait to get it back on the road. The trans is holding up good, I did a full service transmission fluid change at honda around 60k. |
(Post 15324168)
I see CARBON dry carbon everywhere. Diet time!!! |
Originally Posted by TheWrench116
(Post 15324458)
Let's get the ball rolling!! |
(Post 15324186)
awesome, i am due for a oil change shortly so going to do that and the tranny. Only honda ATF right? |
That's what I used. Not sure I will use when the new tranny and tq converter comes into play.
(Post 15325384)
I am interested to see how the torque converter will do. You went for a high stall one right?> |
(Post 15330491)
Not yet, but that is one of many items that will be crossed out from my signature. |
2 Attachment(s)
Oh she is missed!! Can't wait to get it back on the road, track, and circuit!
Attachment 72721 Attachment 72722 |
damn going to be nice once it is all done. I've been thinking of auto-xing mine. Sitting around today waiting for my downpipe to show up.. injectors came yesterday fglashpro monday. Its allll coming together.How did you run your catch can off the pcv right?
(Post 15331893)
Nice, I'm sure you're going upload some vids. Speaking of, I still need to grab a few gopro's! The catch can is ran off the pcv valve and valve cover breather. |
Originally Posted by kraz3RdX
(Post 15335017)
Get it! |
In progress my friends[/QUOTE]
What throttle body did you go with? |
I'm just trying to figure out where the heck his intake and filter will go.
looking forward to this wish it had its own thread though. |
It will when im done
any thoughts on a "race" battery to save space? and potentially mount it someplace else in order to get more room in a very busy location?
I rather have a good battery hommie... Its a daily... Not a race car... Have kids... So dont like taking chances
Hmmm...
How much power u made ben? Im going on the dyno tuesday wen my tuner gets bak in town #Derftuned
280hp
Word... Thats with cams and all right... What size injectors?
(Post 15335132)
Question... U dont have a recirculating valve no more right?
(Post 15335240)
(Post 15335240)
Kraz3 still stock turbo?
I think he is stock.
(Post 15335112)
(Post 15319867)
Most of them will be having around 300 whp on the same dyno where Ken has 280. The difference is in the IAT. Its rarely coming out of +45C on +30C day. The difference between TMIC and a2w ic is 25-35C which is huge. This allows you to have more aggressive tune. Along with what Ken already has this setup will bring him to 300-315 whp easily.
There is also another build in Russia that has Garrett turbo swap, a2w ic and some other goodies. Around 330 whp. Thats what you need in order to get ~13s quarter. I beg to differ ill go to the track this year and get into the 13's |
(Post 15323748)
Before you start to work on turbo you need to already have either downpipe 3" or full exhaust 2.5-3". Additionally you heed to have either FMIC or air-to-liquid IC installed. So this turbo setup consist of original bored hot side, adapter and Garrett GT2860RS. On the photos you can see how hot side is attached to adapter and how adapter is attached to cartridge. Which means Variable Flow will still be working and both solenoids are still there. There are mounts for solenoids on the cold side. This should be installed on the OEM exhaust manifold. What has to be changed/adjusted: 1) Oil feeding: has to be switched to flex feeding and fitting for the original Garrett restrictor 0.9 mm as its a ball bearing turbo. 2) Oil discharge: original Garrett oil discharge should be installed. Original hose can be used or you can switch to a braided one. 3) Coolant feed/discharge: Garrett specific banjo bolts should be used along with fittings. 4) Important: do not forget to use heat shields for all sealings, hoses and pipes. 5) Intake pipe from the IC must be relocated 2 cm closer to the driver side since the 2860 cartridge is longer than the OEM one. Plus, additionally you need to weld 2 nipples (4mm) for variable flow solenoids air supply. ...to be continued is this on the euro/Russian build? |
(Post 15335616)
