i live my life ...
Old Aug 5, 2014 | 02:43 PM
  #41
TheWrench116's Avatar
FLETCH
maybe ill just go get a 5 gallon fuel can and have that as my go home gas...
Old Aug 5, 2014 | 03:36 PM
  #42
RDXturbo07's Avatar
ya i put up the wrong time slip because i couldn't find the other one where I ran the 14.386... what you see in the video was my 2nd best time i ran that night. My best run was a 14.376 that night but unfortunately i have no video of it, but have the timeslip for that run, which you see in the video. Also i was in S mode without using the paddles for my best run. Weight reduction helped a lot, i would suggest taking out the passenger seat and the rear seats, along with the spare tire.
Old Aug 5, 2014 | 03:42 PM
  #43
FLETCH
I made that pass with a full interior + a full tank of fuel I probably weighed 175-250 pounds more then you... that explains a bit.
well I'm going to try to go again this Friday so ill see what I can do. when I ditch the interior and run with an 1/8 tank of fuel.
Old Aug 5, 2014 | 08:12 PM
  #44
Slow98teg's Avatar
The DA has a lot to do with times. Every track is different and every day is different.
Old Aug 5, 2014 | 09:46 PM
  #45
FLETCH
DA??? Air density?
Old Aug 6, 2014 | 11:20 AM
  #46
Slow98teg's Avatar
Density altitude. Acts as if an elevation change.
Old Aug 6, 2014 | 10:50 PM
  #47
Tomtwtwtw's Avatar
Yep...DA is a calculated altitude based on various factors (humidity, baro pressure, temp, elevation, etc). It is meant to be sort of an equalizer to be able to give an apples to apples comparison of times from different tracks in different climates. You can plug your numbers into a DA calculator and figure out what you would have most likely run under ideal conditions.
Old Aug 28, 2014 | 04:26 PM
  #48
BigHatch's Avatar
not an SUV ...a Big Hatch
...when do we see Ken B on Street Outlaws challenging Asian and his dung beetle!?
Old Aug 28, 2014 | 10:44 PM
  #49
KenB350z's Avatar
lol, I have to get in line. They have challenged Alex from Humble Performance already, it should air this coming season.
Old Aug 31, 2015 | 10:43 AM
  #50
KenB350z's Avatar
I see low 14's here all day, maybe you guys should sell your tune.
Old Aug 31, 2015 | 11:00 AM
  #51
Slow98teg's Avatar
Wow Ken. You seem really upset? What gives? What times did you run with all those mods? You seem to have a chip on your shoulder for me. You seem to forget I'm stock exhaust and intercooler.
Old Aug 31, 2015 | 11:03 AM
  #52
KenB350z's Avatar
Do I need less mods?
Old Aug 31, 2015 | 11:08 AM
  #53
KenB350z's Avatar
I haven't ran the car with the new turbo. My old RDX has been on Jack stands till last night, parts were being developed for this platform..
Old Aug 31, 2015 | 11:14 AM
  #54
KenB350z's Avatar
Seems like you discovered fire and I'm setting over here with electricity...
Old Aug 31, 2015 | 11:41 AM
  #55
Slow98teg's Avatar
Well I do love playing with fire. Been playing with fire since a kid. It's quite warm. So why are you upset?
Old Aug 31, 2015 | 11:48 AM
  #56
KenB350z's Avatar
I'm good bra.
Old Sep 1, 2015 | 12:15 PM
  #57
FLETCH
Stock and Mildly Modified Naturally Aspirated Engines
13.423 @ 103.025 MPH
Extensively Modified Naturally Aspirated Engines
13.534 @ 102.269 MPH
Extensively Modified Supercharged and Turbocharged Engines
13.594 @ 101.693 MPH
read into this what you will i ran a 13.677 @ 101.07
Old Sep 1, 2015 | 12:19 PM
  #58
FLETCH
maybe next season ill be in the 12s that would be nuts right!?!?!?!
Old Nov 15, 2015 | 05:34 PM
  #59
FLETCH
He's awd...I doubt tire grip is an issue. At least not when you're currently cutting a 2.1 60', I was able to do that with street tires on front drive in my old car. Need to get more torque flowing at the launch, but there's a fine line between brake-boosting a frying a torque converter.
Also, weight reduction would help...but beyond the spare tire and jack I'm not sure how easy that is. Those rear seat backs are pretty damn heavy though.
the awd still lets us spin the front tires... from a 25 roll i can light em up in a big way if i was going to swap my trans the next day i could probably keep it going into second gear...
Old Nov 16, 2015 | 05:57 PM
  #60
crxtype-r's Avatar
richard cranium
I have an extra trans to build
Old Nov 25, 2015 | 10:15 AM
  #61
FLETCH
contributing factors as to why i didn't run faster...
loose intake manifold bolts cylinder #4 wasn't getting the same air fuel charge as the rest and i was leaking boost...
could have been a contributing factor as to why i didn't build boost at the line. and why my 60 foot sucked...
also installed new plugs gaped to .028 factory gap is .035 seems to run a bit better.
Old Nov 25, 2015 | 10:34 AM
  #62
KenB350z's Avatar
Yeah, Yeah. Drag strip is finish, now it's time to test out that sway bar. You should hit the circuit, much more fun. I think they some really cool there where you are too. Check them out, unless you just like going in a straight line..
Old Nov 25, 2015 | 10:45 AM
  #63
Slow98teg's Avatar
That's probably why you dropped a couple mph too
Old Nov 25, 2015 | 10:55 AM
  #64
FLETCH
yep
Old Nov 25, 2015 | 10:56 AM
  #65
FLETCH
need that BBK in my life first.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
BrownBuck
NY/NJ
Sep 29, 2015 09:53 PM
San Yasin
Sep 29, 2015 10:52 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
