Custom intake
Old Mar 7, 2020 | 07:00 PM
NaturalFlavored's Avatar
Custom intake
Finished my custom intake. Will be taking it to a shop soon to get it welded together. I bought a maf sensor pipe off of Amazon for $31, then a universal turbo kit for $115. Spectre filter for $15. I had extra hose clamps that I used because the ones that come with the turbo kit are bulky, I used a couple around the maf since it was in the open. I also took off the battery/ tray to make it easier.
https://youtu.be/DiW3_IMpdt0
Old Mar 9, 2020 | 03:24 PM
LunaKush_'s Avatar
did the check engine light come on?
Old Mar 9, 2020 | 06:07 PM
No, driven over 100 miles so far no issues.
getting about 24mpg on the freeway, feels like I have less turbo lag.
Old Mar 9, 2020 | 11:08 PM
I moved a couple pipes around to my liking will update pictures soon, maf still in the same place. I just moved the rubber elbow from where it goes to the body/ fog light housing by the battery to the last turn after the maf sensor.
I switched the pipes/ hose piping is all I did. I have to cut the piece because the elbow is now in the way for the intercooler cover.
like I said will post pictures. Both ways work I'm just trying to see how I like the setup
Old Mar 12, 2020 | 05:37 PM
feralcomprehension's Avatar
Qualified Observer
Pretty sweet, well done. Is that your only mod?
Old Mar 12, 2020 | 05:56 PM
Thanks, no I also put a blow off valve.
Old Mar 14, 2020 | 06:20 PM
As you can see I swapped the first and last piece.
I like this setup more then my first, definitely feels less lag when I give it gas.
DDTsx06
Sep 8, 2015 06:56 PM
NSXNEXT
Mar 7, 2008 09:04 PM
JDMCL9T
Feb 2, 2006 03:52 PM
sgmotoring
Nov 12, 2003 09:53 PM
3point2TL
Apr 29, 2001 06:22 AM
