CT-Engineering 520cc injectors
Old Jul 3, 2013 | 11:51 PM
Hecka's Avatar
8th Gear
Lightbulb CT-Engineering 520cc injectors
I was looking around on Heeltoe's website for RDX mods and found http://www.heeltoeauto.com/ct-engine...roductid=66551
This posed a question: Would installing these injectors fix the lean issue that comes with running a hondata reflash, CAI, and downpipe/exhaust mod?
I've read on several threads where it's not wise to run all three as it can cause the car to run lean, so why not add the larger injectors?
Also, how much do you think this would affect fuel economy?
Old Jul 4, 2013 | 09:54 AM
Mr Marco's Avatar
Injector is controlled by the ECU. Pulse amount/duration would be the same.
Old Jul 4, 2013 | 11:42 AM
vaprea's Avatar
Saw that mod listed also, Is states in the listing "Will require aftermarket ECU modifications" & "Not to be used on vehicles with a stock factory ECU"
Im interested if the hondata with the injectors are a good combo or if hondata would need to tailor the tune for them.
Old Jul 4, 2013 | 05:01 PM
wspy's Avatar
2008 Acura RDX
^ It will need to be tailored and Hondata won't do it!!
Old Jul 4, 2013 | 06:05 PM
Hecka's Avatar
8th Gear
Why not?
Old Jul 4, 2013 | 08:00 PM
Lanesky_OH8RDX's Avatar
Because there isn't enough of a market for the RDX as far as modifications. Because of that Hondata will not throw R&D costs at a car that wont give them back more than what they put into it.
Old Jul 5, 2013 | 08:34 AM
Vividsi's Avatar
This is another reason why Hondata SUCKS! we are handcuffed to only 1 option.
Old Jul 5, 2013 | 09:03 AM
08FLrdxSH-AWD's Avatar
KCCO
Agreed
Old Jul 5, 2013 | 10:57 AM
Hecka's Avatar
8th Gear
I'm sure we could take the RDX to any local tuner shop and they'll do a custom tune for the injectors. I mean, that's what they're there for, right?
Old Jul 5, 2013 | 03:49 PM
KCCO
As I understand it, any sort of Honda ECU is not like a typical ECU that can easily be reflashed or simply tuned, that's kinda why Hondata has us by the short and curlys. Now, I am not completely certain bbut another viable option would be to go with a stand alone ECU and work from there, but at that point in time you are talking about a hefty investment of time and money.
Old Jul 6, 2013 | 08:37 AM
wspy's Avatar
2008 Acura RDX
^ Yep...Thats basically it
Old Jul 31, 2013 | 01:56 PM
Vividsi's Avatar
With flashpro coming out this might be a nice upgrade since it can be tuned by a shop who knows about hondata.
Old Jul 31, 2013 | 08:21 PM
user65's Avatar
I'll talk to Hondata and see what they think of me installing these when I send my car back with all the goodies. If he wants to do it I'll invest the resources to get it done.
Old Aug 3, 2013 | 11:20 AM
KCCO
^^^You are going all sorts of hog crazy with your RDX. Love that someone is though
Old Aug 11, 2013 | 09:36 PM
Tizzil84's Avatar
If u are getting a base map programed on your hondata then it should b stock if u mod it u should tune the ecu to control and b able to understand whats going on with the engine and if your local dyno shop doesnt know how to tune your hondata or u are to cheap to tune it the stay with your intakes and exhaust and put your money else where like vinyl stickers.
Old Aug 12, 2013 | 07:21 PM
KCCO
The thing is, with this new hondata coming out we are finally able to get a little more ability to actually fine tune each modification we do. With the normal handata tune, there is nothuing that you can change. Even the most reputable shops will not try to mess with the Honda ECU because, like a toyota, it is locked.
Old Aug 12, 2013 | 09:57 PM
Tizzil84's Avatar
Yeah but if it has hondata on it that should b able to reprogram the chip they install on it just like flashpro or u could do what I am going to do and use the aem saem.
Old Aug 13, 2013 | 07:38 PM
KCCO
Hondata isnt a chip, its a program. Hondata is in the middle of developing flashpro for us but we are still waiting on those results. Otherwise, a base hondata tune cant be changed or modified by some joe schmoe shop
kraz3RdX
Oct 12, 2015 09:12 AM
Nitin
Sep 30, 2015 08:22 PM
Leester01
Sep 11, 2015 06:35 PM
Gary Matthews
2G CL Problems & Fixes
Sep 11, 2015 01:21 PM
NSolace
Sep 3, 2015 08:14 PM
