Blow Off Valve
Cooljust (05-31-2013)
Don't get the ones for the subaru since they are facing a different angle and non adjustable.
Also stick with the bypass valve -
I'm checking this out as one of my next mods, and since I have very little knowledge of turbo charged cars, how will this benefit? Smoother and more even response or flow? I'm trying to justify if this is a worthwhile investment, or if it's just for the sound.
Is this the BPV I'm looking for? http://www.forgemotorsport.com/conte...duct=FMDVMSP02
Has anyone used this BOV?
Here's the product you want to replace the stock BPV. Not a bad price considering it's metal and the OEM BPV is $80 to replace.
https://www.streetunit.com/ProductDe...e=TS-0997-1009
Looks Legit, no mods needed for install, looks like it bolts right up to me...
anyone order yet? curious on how it sounds.. also did you choose the standard 10-20psi? or the standard plus high pressure?
I ordered it, and installed. I think I got the high pressure, I don't remember.
Honestly I'm probably not going to reinstall after the hondata flash pro. Sounds a little different, but not much. I read a write-up by pang or whoever did that custom downpipe awhile back and he claimed the stock plastic bpv is really good, even tho it's plastic. I'll bring it with me to the re-map with mods to see what Hondata thinks when they hook it up to the 'puter.
edit- yes it bolts right up, you may have to bolt it down in order to get the base to adjust though, at least I had to. The only thing you'll need is a hose clamp since the hose doesn't fit tightly on the TurboSmart BPV.
good to know.. probably nice to have the higher one just incase i turbo upgrade
