analyzing first datalog
Old Mar 21, 2015 | 09:47 AM
csargemg's Avatar
So, this is my precious first datalog. I figured I would set a very simple first tuning goal for myself. It is this: To determine how close I was under normal (but heavy) driving conditions to my injector duty limit, with stock Hondata tune + my silly intake mod (K&N drop filter + snorkel replaced with 3" ducting).
It looks like, making sure that I had a chance to redline in 2nd, and some push earlier, that the closest I got was 58%. Obviously I need to learn how to drive a datalogging cycle. However, it does show that I get up to like 14.1, 14.2 boost as it is?
In any case, here's my very first datalog. Thoughts are appreciated, as well as instructions on how I should approach analyzing myself! I can't quite figure out how to bring up the fuel low window in Flashpro in one of the instruction videos to check A/F ratio, but since I was checking injector duty at redline in 2nd, and accomplished that, well, hey!
Aww, isn't this cute.
File Type: zip
Old Mar 22, 2015 | 10:40 AM
KenB350z's Avatar
Dang it, still in the process installing windows on this damn Mac. I hope to view it soon to see what it looks like!
Old Mar 22, 2015 | 02:22 PM
csargemg's Avatar
Forget about this one, I'll have a better one posted this afternoon.
Old Mar 22, 2015 | 02:37 PM
KenB350z's Avatar
Nice!
Old Mar 22, 2015 | 06:43 PM
csargemg's Avatar
Okay. These are vastly better. I made sure to redline at least once in each, and got a log of high revs, lots of WOT both in D and S.
I promise, I do not ordinarily drive this hard!
File Type: zip
File Type: zip
Old Mar 23, 2015 | 12:01 PM
TheWrench116's Avatar
FLETCH
looks like 78% was the max ? and that's with what ever you've got in it at the moment. and that's before you raise the boost more.
Old Mar 23, 2015 | 05:47 PM
csargemg's Avatar
That is with nothing but flashpro using the stock performance tune, K&N drop-in, and the intake snorkel replaced with 3" performance ducting. The filter box and the connection from the filter box to the intake is untouched.
Old Mar 23, 2015 | 08:44 PM
csargemg's Avatar
afr adjusted for k&n drop-in + flashpro.zip
All right, TheWrench let me know I was running a little lean. So he helped me out with fixing the top end A/F ratio. Apparently 12 or just under is a good goal on FI. Anyway, many cheers to him. But anyway, here's a contribution - a not unsafe map for Flashpro with K&N drop in filter. Datalogs to follow.
Old Mar 23, 2015 | 09:22 PM
FLETCH
I think I sent the post rv6 install map to the right email this time. its safe until you get with vit for a all around better tune.
Old Mar 24, 2015 | 08:10 AM
rdxchris710's Avatar
RDX faN BoY
3rd gear pull wot to the limiter is the best gear to datalog, do pulls.
Old Mar 24, 2015 | 09:21 AM
GSJake's Avatar
So he was at almost 80% duty cycle with just his flash pro??
Old Mar 24, 2015 | 11:33 AM
csargemg's Avatar
Just flashpro, K&N drop-in, and snorkel replaced with 3" performance duct.
Old Mar 24, 2015 | 11:55 AM
csargemg's Avatar
Here's a datalog before RV6 dp install. This is just reflash + K&N drop-in + replaced snorkel.
Old Mar 24, 2015 | 12:00 PM
GSJake's Avatar
I know you are excited about this k&n snorkel mod. But I dont this it plays a major role.
I will be interested in seeing mine when I get that CP-E on it.
Hondata says it should be fine. As a bonus I have 93 octane where I live.
Reflash - Acura RDX
Hoping to have my intake, iC and exhaust on next week.
We shall see!
Old Mar 24, 2015 | 12:03 PM
csargemg's Avatar
Excited? I don't think it does much. I think it's a much milder mod than getting a proper short ram air. Maybe it does a little.
Old Mar 24, 2015 | 12:20 PM
csargemg's Avatar
Ach, my datalog is too big to upload! I'll do a smaller one on the way back after dp install.
Old Mar 24, 2015 | 12:37 PM
GSJake's Avatar
Okay Okay.. maybe stoked. NOT trying to rip or anything!
Old Mar 24, 2015 | 01:02 PM
KenB350z's Avatar
You know, you be like!
Old Mar 24, 2015 | 01:58 PM
csargemg's Avatar
I would say...mildly diverted. The excitement level is about the same as for my smartphone mount.
OK fine you got me, I'm
Old Mar 24, 2015 | 11:38 PM
csargemg's Avatar
So, I got that RV-6 with high-flow cat installed, and it's certainly something you can feel. Here's a datalog from the 50 mile trip home - no CEL yet. Odd, because it was part city and part highway - I expected that to be a drive cycle.
drop-in + downpipe.zip
Getting 600cc injectors.
Old Mar 25, 2015 | 03:55 PM
RDX faN BoY
Attachment 28518
I'm installing my downpipe as we speak.. BTW josh told me your in Boston only 45mins away we will have to meet up soon. This dp is kicking my butt.. Its so damn tight back there. Should be better when I take this dogbone off.. trying to get the primary cat out right now.
Old Mar 25, 2015 | 10:16 PM
FLETCH
yes yes he is. and this is why I tell everyone get injectors...
if the injector is this close to static (always open) you lose control of the fuel aspect of tuning. then what do you do if a cylinder runs lean??? could get lucky might be buying so of that there motor...$$$$. ouch
1800.00 motor
369.00 4 brand new 800cc injectors!!!!
once vit viper and doug get the kinks worked out you'll be looking at 280whp with flash pro injectors downpipe and a better intercooler.
and that's on the stock cat-back!!! so it will be quiet!!!
ExcelerateRep
Oct 14, 2015 08:20 AM
nyckid
Jun 9, 2005 08:42 AM
