08 RDX injector upgrade ???
Latent car nut
Received 2,005 Likes
Just looking to see what has been done and anything over the rated 410cc looking at either 600 or 800cc
QUOTEQUOTE=horseshoez;16188130]What do you consider an upgrade and why are you considering it?[/QUOTE]
Latent car nut
Hmmm, do you realize gasoline engines are throttled by air and not fuel? Upgrading the injectors without any other changes will do nothing for performance while at the same time dilute the engine oil and potentially cause rather significantly accelerated engine wear as the oil dilution increases following each oil change.
Yea actually I do know that being I'm a master mechanic lol just looking for injectors and there are plenty of mods that I have done just not many people post what injectors they use on here.
There's always that one guy with a response off the wall lol....
ID1000s is what i ran or FIC is great too. Only ones I'd recommend. Both are great brands with all the needed injector data needed to input into flashpro and not drive like crap. Matched flow rates and all that jazz.
Latent car nut
Latent car nut
Latent car nut
The devil made me do it.
he asked what injectors people have upgraded to and any issues they had if any. I answered my experience. You did not. This is a performance forum. The stock injectors are maxed out with just a good dyno tune. He's made other posts asking about other mods so he wants to go bigger with the injectors.
Latent car nut
MrHeeltoe (02-13-2019)
I've read and tried to comprehend to the best of my ability but my question is about the injector size i need to order (based on the Flashpro basemap calibrations). The base calibration from flashpro is for sri, dw600 and 3” mid pipe with highflow cat.
I am doing the downpipe with high flow cat instead of mid pipe and if i want to add tmic or cat back exhaust later, would i be maxing out the duty cycle of 600cc injectors? Should i go 800 to allow for other bolt ons?
2008 Acura RDX
Thanks I appreciate your responses. I am reading most go with 800's and I will too. Now im stressing about if I need to ug the fuel pump at the same time lol.
is there a spec for pump performance in relation to injector size/demand?
Thanks again
Thanks again
Although since my stock fuel filter was clogged, I was getting this annoying ass rattle under my dash from the fuel regulator.
Upgraded the fuel pump and filter and it was gone.
https://acurazine.com/forums/1g-rdx-...-wheel-951185/
good to know I can ug later (when funds allow) and install the DW800's for the bolt-on's I am planning. thx
Would I need to drop the tank to check the filter?
Once you unscrew the cap (or whatever you call it), the fuel pump assembly lifts out and the filter is on the bottom attached to the pump.
IntactACK
71
09-19-2020 04:55 AM
simione
03-09-2017 01:14 PM
MrHeeltoe
11-22-2013 10:32 AM
rtatsutani
10-26-2005 11:36 PM
