Spark Plug
Old Jul 30, 2008 | 10:25 PM
littleblazer's Avatar
Spark Plug
I put new plug today I notice #2 plug upper valve cover o ring is little wet around.
Oil is comming thru. got 45000 mile on 2007 RDX.
I guess next time i have to change the valve cover gasket.
Plug seen ok but i still change it anyway.
it took less then hour to do this.
I pay 15.00 dollars each from dealer. i got commercial account with them.
Car run great like new.
Old Aug 29, 2008 | 12:19 PM
happywithmyrdx's Avatar
pricey plugs!
I suppose the plugs are something really, really great, but what type of plugs did they sell you? I'm curious, since most plugs cost $2, with the platinum costing about $4.50 or so. Even with a dealer markup, I'd be curious to see what plugs they are. Most seem to be NGK sourced.
Old Aug 30, 2008 | 08:01 AM
mau108's Avatar
www.sparkplugs.com
they had 2 models, one that had the special "technology" where it stores some power and gives more of a big bang. BUT I did read that a lot of people were having build quality problems, looks like they took it off.
Denso long life is the only one there
Old Oct 1, 2008 | 07:00 AM
claude2's Avatar
4th Gear
Could you tell me if it's difficult to change plugs, with the air cooler on top of engine, etc? I suppose that it has to be disconnecte4d and removed?
Any reference would be appreciated.
Old Oct 10, 2008 | 08:05 AM
Rexorg's Avatar
Why were you changing the plug? From the info you provided your RDX is still under warranty. You need to go back to the dealer and have the service department check your engine out for leaks, loss of compression, etc. If you have problems communicating in English ask if someone there speaks your first language.
Mike734
Dec 10, 2021 01:25 PM
acuratl26
Apr 23, 2020 07:30 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
