Running Boards Installation
Old Sep 11, 2007 | 03:16 PM
ToToKing333's Avatar
Guys,
Has anyone tried to install the running boards themselves? I am thinking to order the running boards from ebay for ~$425 - $450 and install myself. Is this something I could do at home without any heavy duty equipment? Thanks!
Old Sep 11, 2007 | 04:31 PM
johnny99's Avatar
I have not done this, but looking at the instructions, I think it will be pretty easy if you are able to lift the car a few feet off the ground. If not, the job could be a real hassle.
Old Sep 11, 2007 | 04:34 PM
richmond5's Avatar
Its done using https://acurazine.com/forums/showthr...=running+board. Fairly sraight forward. You don't have to lift the car at all, for me! Good luck!
Old Nov 15, 2007 | 09:04 PM
gstyper's Avatar
Installation is easy with the instructions above. It took all but 15-20 minutes per side and you don't have to jack up the car (I'm 5'6"). You can get the running boards from ebay for 400 shipped.
Old Dec 10, 2007 | 11:10 AM
ashsehgal's Avatar
I have done it myself. Doable but it took me 4 hours with help from a friend. No need to jack up the car, need simple tools.
Old Dec 10, 2007 | 03:16 PM
sasair's Avatar
4 hours and how many beers? That seems like an awfully long time for that install.
Old Dec 11, 2007 | 09:04 AM
ashsehgal's Avatar
I excluded the beer time
Actually to understand the thing takes time and as you go along it takes lesser and lesser time to do the same task again, trust me it can be done faster if i do it again.
Old Mar 28, 2008 | 10:14 PM
Acura604's Avatar
2024 RDX A SPEC
just did this myself.. spent my time doing it... took about 2hrs. I did run into 1 minor problem.. ONE of the bolts that was to be used to secure the rear bracket under the car
would not go in.. it was like the actual screw hole inside the car where the bolt would screw into was stripped and causing the bolt to go in at an angle no matter what. I'll get the dealer to put that one in.. otherwise, all is secure.
Old Jul 2, 2008 | 04:03 PM
oilerfan's Avatar
Do you need to use a torque wrench (to tighten the bolts to 20 lb-ft) - or is a socket wrench fine?
Old Jul 2, 2008 | 06:32 PM
vrflyer's Avatar
20lb-ft isn't much, so a socket wrench will do fine. Throw in a 3/4 turn after it's hand tight.
Old Jul 2, 2008 | 10:14 PM
oilerfan's Avatar
Thanks vrflyer!
Old Jul 4, 2008 | 10:42 AM
Alexandros's Avatar
Where are folks getting the running boards and how much are you paying for them.
I checked with my local dealer where I purchased the RDX and they want an insane amount for them.
Old Jul 4, 2008 | 12:30 PM
vrflyer's Avatar
Try eBay, sometimes there are some good deals enough to save a few $$$'s.
Old Nov 12, 2008 | 07:06 PM
CSpaR's Avatar
I found some Acura dealers o nthe E coast sellnig them for $400 plus about $30 for shipping. Not bad, considering the dealer wants $560 for the runners, PLUS installation, PLUS tax. Yikes.
I ordered mine and will have them this Friday.
Old Nov 14, 2008 | 02:59 PM
neo1738's Avatar
2016 MDX Adv/SHAWD
honda acura world...great prices usually
Old Nov 15, 2008 | 11:51 AM
VeNeNo's Avatar
El Chulo...
Thumbs up
+1 thats where i ordered mine from.
Old Nov 17, 2008 | 06:58 PM
CSpaR's Avatar
Okay, installed mine Friday night, in about a hour or so. Was very easy. Just a bunch of bolts that matched up to holes in the frame. Put the arms together, bolt on the rails and your good to go.
I've done a bunch of installs on my TSX using the factory Acura instructions, so I know what to look for now. That's probably why it only took about a hour or so.
Feb 25, 2020 09:57 AM
spidermankb
Mar 5, 2019 11:34 AM
Fabian43
Jul 13, 2016 09:07 PM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
christopher1
3G MDX (2014-2020)
Sep 10, 2015 06:43 PM
