Replacing third/tailgate brakelight bulb
Old Dec 6, 2011 | 12:10 PM
sodaks2k's Avatar
I've searched "3rd", "tailgate" and "brake" to no avail. I even searched the www. A girl I work with has an RDX and her third/tailgate bulb is out. To replace it the bulb, do you remove the cover from the outside or the inside? THe parts breakdown is only so helpful. Thanks!
Old Dec 6, 2011 | 02:26 PM
hhrdx08's Avatar
You remove the cover from the outside. There is a little cover on each side with a tiny slot to pry open. Once open, you will see the screws...
Old Dec 6, 2011 | 02:47 PM
sodaks2k's Avatar
Thank you! Now I have to try to find her a bulb, locally hopefully.
*edit* after some more searching, I'm going to direct her to get a stanley 921LL from the local parts tore.
Old Jun 2, 2012 | 03:28 PM
BaNdOrA's Avatar
Hey, I'm sorry to bump this thread, but I am trying to change the tail lights too.. but I can't figure out how.. I have read hhrdx08's post about it, but I still don't get it.. Is there like a video tutorial.. or pictures? Thanks in advance..
I tried to pry open the black cover around the tail light, but it's stuck.. and I think I might've broke it.. Not sure though lol.
Old Jun 2, 2012 | 11:28 PM
hhrdx08's Avatar
Hey BaNdOra, we were talking about the third brake light on the top of the tailgate. I believe you are talking about the lower brake lights left and right, right?
After removing the two screws from the housing, you just need to pull a few times (each time a little bit harder) on the housing straightly toward yourself. It felt stuck because there is a small piece of plastic holding the housing in position. It will come out if you use enough force. Have fun.
Old Nov 20, 2013 | 01:23 PM
thephantom's Avatar
I unscrewed the two screws, but can't pull the unit out. Any suggestions?
oo7spy
Jun 19, 2023 12:48 AM
pplcrew
Jan 30, 2021 08:59 AM
acuraST
Sep 17, 2015 02:31 AM
brjones9
Sep 3, 2015 07:30 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
