Replacing RDX Headlamp assembly?
I need to replace my left (driver's side) headlamp assembly. It is cracked and moisture is building up in it and has killed the HID ballast. Any guidance on where to find a replacement cheap,and, any tips on doing the replacement myself? Thanks in advance for any guidance you can provide.
You can find the headlamp assembly on eBay. Just look for the color that matches your body.
I have not done it but it looks simple; just remove the bumper, bulbs and headlamp assembly. You'll need a flat head and 10mm for the fasteners.
