RDX oil change 7,500
Old 10-14-2024 | 03:13 PM
genesis211's Avatar
I have a 2008 RDX and the maintenance schedule states replace oil initially at 7,500 then at 15,000, then at 15,000 intervals. Is this accurate. Can the synthetic oil really last that long? Thank you.
7,500-Mile Service
7,500 miles marks the first Acura RDX oil change interval, plus tire rotation and a multi-point inspection, including:
Air Cleaner Filter
Air Conditioning Compressor
Air Conditioning Refrigerant
Battery Condition
Brake Lines, Hoses, and Connections
Exhaust Pipe and Muffler
Front Brake Disc/Pads, Calipers
Rear Brake Disc/Pads
Steering Gear Box, Linkage & Boots/Lower Arm Ball Joint, Upper Arm Ball Joint
Suspension Mounting Bolts
Vacuum Hose
15,000-Mile Service
At the 15,000 miles Acura RDX service interval, it’s time for another oil and filter change, tire rotation, and another multi-point inspection. Other maintenance tasks include:
Change rear differential fluid
Change engine oil
Inspect brake system
Inspect exhaust system
Inspect brake lines, hoses & connections
Inspect cooling system hoses & connections
Inspect fuel lines, hoses & connection
Inspect parking brake
Inspect suspension components
Inspect steering gear rack, linkage & boots
Inspect boots & seals drive axles
Replace oil filter
Rotate wheels & tires
30,000-Mile Service
Change engine oil
TheNewAcura
1G RDX (2007-2012)
08-21-2013 04:15 PM
foam4me
02-17-2010 05:28 PM
narnia
06-12-2008 08:15 PM
xjohnkdoex
05-29-2008 10:30 PM
Jerky
01-28-2005 08:09 PM
Quick Reply: RDX oil change 7,500
