Make oil changes easier you say!?
Old Jan 12, 2014 | 06:57 PM
Lanesky_OH8RDX's Avatar
https://www.qwikvalve.com/
I found this product thanks to a friend a while back and forgot about it until now since I have an oil change coming up. Anyone on here have this product? seems pretty simple and effective. Should make doing an oil change that little bit less messy.
Thoughts?
Old Jan 12, 2014 | 07:14 PM
BU's Avatar
BU
I have Fumoto Valve on my TSX.
It works wonder.
Make sure you also get the "ADP-106: ADAPTER 14mm-1.5".
Since RDX valve need extension to install.
BU
Old Jan 12, 2014 | 07:20 PM
Great to hear, I will do that. They also have a new adapter so you can attach a tube so you can aim the oil as you drain it
Old Apr 22, 2014 | 03:37 PM
Papachristos.James's Avatar
Now, I wonder if this material can withstand the elements ie; harsh winter salty corrosion.
The main reason I ask is because they don't state what type of metal this is constructed from.
Old Apr 22, 2014 | 04:42 PM
Brass is my guess.
Old Apr 24, 2014 | 05:55 PM
dcmodels's Avatar
What happens when the drain-device is hit by something (a rock)? I personally don't like the idea of something hanging down lower than the oil pan.
Old Apr 24, 2014 | 08:01 PM
There is a retaining clip to prevent the valve from opening inadvertently. Also it is metal, should stand up to any flying rocks. Now if you are talking a solid rock.... then I ask why are you off roading in an RDX? I'm talking more than a gravel road here.
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
Allen_442
Sep 8, 2015 06:01 PM
kixo
Sep 5, 2015 08:54 PM
