Can't remove ECU
Old May 16, 2011 | 09:47 AM
x2lacrosse's Avatar
Can't remove ECU
Want the reflash and read the guide on Hondata. Sounds pretty straightforward, but I can't even get the connections off of the ECU. Guide on Hondata says to use tabs on underside of each connector. Should be a simple push up on tab and pop connector off, right? Well, I already broke one of the tabs so am I missing something, doing it wrong or is it years of dirt, heat, etc that has caked the connector on?
Old May 17, 2011 | 01:19 PM
chipmunk's Avatar
I believe you just have to pull up harder to pop the connector out. Don't yank on the tab, but use some force.
I had the same problem as you did. I tried to remove it at night and couldn't see what I was doing. I tried again the next day and was able to get it out.
Old May 19, 2011 | 07:59 AM
x2lacrosse's Avatar
I'll try again, but remember that I already broke one of the tabs completely off so shouldn't that connector just come off now?
TypeS860
Jan 10, 2026 11:11 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
dainmezron
Oct 16, 2015 06:56 PM
Skirmich
Oct 1, 2015 12:59 PM
malvothegreat
Sep 29, 2015 12:38 AM
