XM Modulator Box -Dice iPod Adapter
I purchased the DICE iPod unit (with text display) discussed here elsewhere. The install went smoothly (I had a stereo shop do it), but with one problem. XM radio sound still comes through when trying to listen to the iPod. The stereo shop knows the XM modulator has to be disconnected, but they can not find it! Does anyone know where this box may be located so it can be disconnected?
Thanks for the response. For any others that run into this, here's what I figured out: For this specific Dice unit, the antenna at the rear of the car (under the headliner) does not need to be disconnected. In fact, it does remove the XM audio, but makes the Navi screen flash "Check Antenna". The key is to unplug the XM module behind the glove compartment like the post above says. It is located in the upper right area (towards the front passenger wheel) and says Delphi electronics on it. Hope this info proves helpful for anyone trying this unit.
As a side note, the Dice unit works great for anyone looking for your navi screen to display the iPod song & title information.
Ipod Adaptor Help
Hi,
I was thinking on adding the Ipod adaptor to my RDX, but I have a couple of questions:
Are you able to view videos from your ipod gallery in your navigation system?(like DVD movies that you have on your Ipod video gallery)
Once the ipod is connected can you still view the other screens in your navigation system? (Screens like the map/guide/trip computer, etc)
Thank You
Thank You
InFaMouSLink
Oct 30, 2015 09:43 AM
TLguy42
Sep 26, 2015 11:27 AM
