USB interface - playing order question
Old 03-23-2011, 11:08 AM
4th Gear
keleven's Avatar
Curious if others have encountered this issue playing audio files on a flash drive through the USB interface.
I have all the music sorted into folders. A few folders have subfolders, not sure if that's significant. The files are all in the proper playing order when sorted alphabetically/numerically - no playlists used. (For example, the filenames in the folder "Dark Side of the Moon" are called "1. Speak to Me.mp3," "2. Breathe.mp3," etc.) But it seems when the audio system opens a folder, what it considers track 1 is not the actual first sorted file. For most folders, its idea of track 1 seems to be about 3 or 4 files from the beginning, for a few folders it seems to be about 3 or 4 files from the end, and I can't seem to discern any pattern in how it makes this determination, other than it's always the same for each folder.
Has anyone else experienced this issue? What did you do to resolve? (Would a playlist take care of it?--does the system even recognize playlists?)
The USB plug-in is such a great feature but I have to say it seems to have more than a few frustrations. (E.g., why couldn't they have programmed this thing to play FLAC files??)
Old 04-15-2011, 03:51 PM
Tom-TX's Avatar
All I know is that my son's Ford Fusion has a better USB play back system.
Old 04-26-2011, 11:45 AM
4th Gear
keleven's Avatar
Quite frustrating! Weeks later and I *still* can't figure out how this thing is ordering folders or files. The files get played in alphabetical order yet never starting with A. The order of the folders seems completely random.
Old 04-26-2011, 01:30 PM
Mr Marco's Avatar
Same issue with TL. You can search for it here on AZ, but I don't think anyone has solved the problem.
Old 04-28-2011, 04:22 PM
4th Gear
keleven's Avatar
Thanks for the tip.. one post there (https://acurazine.com/forums/showpos...6&postcount=27) suggests the folders may be ordered by date created, which solves one mystery. I'll have to try touching them to the same date/time stamp to see if that orders them alphabetically. I still can't figure out what it's doing with the individual files.
Old 04-28-2011, 04:35 PM
4th Gear
keleven's Avatar
Another thread with some suggested fixes:
https://acurazine.com/forums/4g-tl-audio-bluetooth-electronics-navigation-294/usb-flash-drive-help-708421/
Old 05-01-2011, 09:12 PM
catnippants's Avatar
I am consistently AMAZED at how these factory USB interfaces can't even do the most basic things that even the cheapest MP3 player can do. It's like the guy that designed the interface never used an MP3 player. I just don't know what Acura/Honda was thinking.
Old 08-03-2017, 04:10 PM
gamini's Avatar
how to reorder the way USB plays
To make sure the USB players in the order you want it to play, place a number in the file name.
Like this:
1 Vanish Disk 1
2 Vanish Disk 2
3 Vanish Disk 3
If not the playback is according to some random order (I think last recorded first played or something like that.) With the number, it will play 1 Vanish Disk 1 then 2 Vanish Disk 2 then 3 Vanish Disk 3
Randy99CL
04-07-2016 06:00 AM
bailey24
11-21-2015 08:43 PM
SilverJ
1/2G MDX (2001-2013)
09-21-2015 02:40 PM
datadr
09-12-2015 09:12 PM
Nicho863
09-03-2015 09:16 PM
Quick Reply: USB interface - playing order question
