Shark Fin Antenna
Old Oct 14, 2007 | 11:21 PM
JMJ3rd's Avatar
'06 RL Tech
Shark Fin Antenna
Has anyone thought about a replacement for the stubby whip to a shark fin style? Does anyone know of any?
Old Oct 15, 2007 | 12:42 AM
WantRDX's Avatar
Future RDX Owner in 2009
Can the RDX go through a normal car wash with that antenna? I asked the dealer and they said "don't use a commerical car wash". Is that true? It does seem to stick out quite a bit.
Old Oct 15, 2007 | 01:41 AM
VeNeNo's Avatar
El Chulo...
Post
the antenna is works perfectly fine, it is not in the way for any carwash... a shark fin alla BMW would be sharp though...
Old Oct 15, 2007 | 03:41 AM
ACURascal's Avatar
You know, the Owners' Manual (2008 Tech) says:
"Your vehicle is equipped with an antenna at the rear of the roof . Before using a ‘‘drive-through’’ car wash, remove the antenna by unscrewing it by hand. This prevents the antenna from being damaged by the car wash brushes."
I can see some top rollers for some drive-thru car washes having some trouble with the little whip.
-AR
Old Oct 15, 2007 | 08:23 AM
bialkoni's Avatar
Go Buckeyes
Talking
I go thru my car wash once a week since February, I have had no problems with the antenna yet. It is actually pretty small. The car wash I go thru does not have the rotating brushes though. It is mostly brushless with a few cloths that go over the top of the car, I do have a roof rack so that may deflect part of it though.
If you want to be on the safe side you can always remove it.
Old Oct 15, 2007 | 08:29 AM
MMike1981's Avatar
big shot.
I have always unscrewed the antenna...you never know, if something gets a hold of that
Old Oct 15, 2007 | 08:52 AM
XIS's Avatar
XIS
Lizard King
Wash your own car people.....
Those machines are not good for wheels or paint...
Old Oct 15, 2007 | 09:43 AM
MMike1981's Avatar
big shot.
Id love to wash it year round, except you cant do that when its 20 degrees out =( Winter leaves you few options
Old Oct 15, 2007 | 09:58 AM
XIS's Avatar
XIS
Lizard King
I know - I hate winter!!! It gets down to about 65 degrees here....
Brrrrrr Brrrrrrr
Old Oct 15, 2007 | 10:18 AM
ShadowGirl's Avatar
Brrrrrr Brrrrrrr
You must have to get out your parka and toque for that chilly temperature...how do you handle it?!
Old Oct 15, 2007 | 03:49 PM
XIS's Avatar
XIS
Lizard King
Well the heated seats, of course!!
Old Oct 15, 2007 | 08:22 PM
mau108's Avatar
wow i didnt know the antennas came off. I work downtown and they are building condos next door soo that company has to cover our cars (cement droppings = no no) and that cover really puts a strain on the antenna.
If the rubber piece can come off, im pretty sure someone can fabricate a body color fin to screw on top
Old Oct 15, 2007 | 08:24 PM
mau108's Avatar
something like this but isnt a stick on type
http://cgi.ebay.ca/EURO-SHARK-FIN-AN...QQcmdZViewItem
Old Oct 17, 2007 | 09:21 AM
JMJ3rd's Avatar
'06 RL Tech
Yeah, just like th at but that works. I went to the dealer to look at the RL's antenna, but the wiring is completely different.
I just like the look of the shark fin over the whip. I've had no problems with it.
Old Oct 17, 2007 | 10:07 AM
sasair's Avatar
The reason we have a whip is because our antenna is for XM/AM/FM. In the RL and TL, the shark fin type antenna is only for XM and the AM/FM antennas are in the rear glass. The AM/FM antenna needs some length to be effective. If you replace the whip with a shark fin expect your AM/FM reception to take a good hit.
Old Oct 18, 2007 | 09:35 AM
JMJ3rd's Avatar
'06 RL Tech
I'll live with it then. Thanks for the info.
Old Oct 19, 2007 | 09:42 PM
turboted's Avatar
I've never had a problem with my stubby whip antenna, I can always keep it up the a car wash.
I have had more problems with rear window wiper arm in car washes. I had one ripped off in car wash. Now I mostly hand wash my RDX. When I do go to a car wash, I go to one that tapes down my rear wiper.
Old Oct 20, 2007 | 06:38 AM
JMJ3rd's Avatar
'06 RL Tech
This is from a Toyota post. Would this address the AM/FM reception? It would look good too, if it would work. Looks like this would replace the mast and cover the base.
Scroll down to pix.
http://www.toyotanation.com/forum/sh...=208385&page=2
Old Oct 20, 2007 | 08:33 AM
mau108's Avatar
looks like it will help.
Old Oct 20, 2007 | 09:21 AM
sasair's Avatar
Hard to say how useful it would be. It would need to be big enough to fit over the antenna base that is already on the roof. This contains the satellite antenna I believe. The little stick on antenna inside the fin may help with radio reception, but it obviously won't be as good, but maybe good enough. In order to make it really work, I think you'd need to modify the antenna base that is currently on the roof. Extracting the XM antenna from it in order for it to fit under that fin. A new antenna base would cost about $70 if you wanted to play around with that idea...
Old Oct 22, 2007 | 12:49 PM
brizey's Avatar
I never take it off for the car wash.
BTW: Wash with towel dry = $2.99 at a place here in Frisco, TX on Wednesdays. Screw washing it myself. I'll deal with a few swirls and spend Saturday morning playing with my daughter. They do a wash and hand wax for $35.
Old Oct 22, 2007 | 08:47 PM
SwampGas's Avatar
/etc/car
Scroll down to pix.
That type of antenna is not very effective. The AM is usually in the headunit (it's a ferrite core with wire wrapped around it...about the size of your pinky). The FM should be a long stick with the metal of the car underneath it (whip) or a T shape folded over itself in the window (folded dipole). These new fangled designs look nicer, but have poor reception.
The manufacturers of those type of devices can say whatever they want....proof is in the pudding
Old Jan 23, 2008 | 10:41 AM
rdx2008's Avatar
Can you please share the location where you get $2.99 wash with towel dry?
Old Feb 8, 2008 | 10:33 AM
imlou's Avatar
My sales guy friend told me they took a RDX through a car wash with brushes and the rear spoiler flew off. So I would only use touchless car washes.
Old Feb 13, 2008 | 03:30 AM
Blingin's Avatar
Talking
He is right I've tried to fit the antenna on top of the base of the RDX is too big for the shark fin antenna to cover, we have to remove the base if you want to to get it to fit. And it only replaces radio reception.
Here's the link.
http://www.visualgarage.com/home.html
I actually help painted some of these in the weekend as a part time.
Old Feb 13, 2008 | 11:02 AM
mav238's Avatar
since you live in the desert, i presume you don't have issues with cold temps, like some of us do.
Try washing your car at below 32 F right through winter, guaranteed way to get arthritis in your old age.
I have used the touchless car wash all through winter, it's not ideal in properly cleaning the car, but to just remove the salt, grit and grime, it's okay.
Old Feb 13, 2008 | 12:55 PM
vrflyer's Avatar
^^^ Look weak, IMO.
Old Apr 6, 2008 | 07:03 PM
J3diMast3r's Avatar
07 RDX/Nighthawk Blk/Tech
The antenna is not an issue for me since I live in Southern California and I get my RDX hand washed at my local car wash. There's no spinners or automated car washes around here.
Old Apr 6, 2008 | 10:49 PM
BleuM&M's Avatar
User-approved
Originally Posted by vrflyer
^^^ Look weak, IMO.
Dude, come by here when it's ZERO, lay down on frozen concrete and let me drive over you while you hose off the salt and crud on the bottom of my RDX. Oh, and wash it too, then dry, and don't you dare leave a scratch anywhere. I'll pay you $50 so you can do it by hand. And please, in 4 minutes, I have someplace I need to be.
I pay $17 for a brushless warm soapy wash (with tire shine & Miracle! Spray! Wax!), that underbody wash and a blow dry. All I have to do is get out and take off the baggie they put on my rear wiper if it didn't blow off already. After 6 months, no scratches, no swirl marks, no haze on NBP.
When it's warmer I'll do it myself, do a better job everywhere except underneath and drink at least $2.99 worth of beer.
Old Apr 7, 2008 | 12:37 PM
R*D*X*'s Avatar
I got free life time car wash from my dealer!!
Old Apr 8, 2008 | 10:45 PM
BleuM&M's Avatar
User-approved
Me too, but they run it through something from the 70s and follow it up with gravel-encrusted towels. No thanks, even tho they have free Starbux coffee. The 2 other dealers I used (FL and MI) washed my rides by hand and did an excellent job. Just show up on Sats between 9 and 12, free coffee and nosh. The MI guys must have spent a fortune on pastries - top drawer.
oyayjoe
Jan 1, 2019 10:17 PM
us285126
Oct 2, 2015 02:03 PM
rhdune16
Sep 28, 2015 11:31 AM
Tonystlx
5G TLX Problems & Fixes
Sep 20, 2015 11:47 PM
oyayjoe
Sep 12, 2015 04:40 PM
